Old 10-25-2025, 06:03 PM   #201
jjzepplin
jjzepplin's Avatar
Re: 72 2wd project "No Daggum Money"
I bought the Tanks inc unit. I also dug deep into the pump install.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-26-2025, 03:35 AM   #202
jjzepplin
jjzepplin's Avatar
I cut the BIG hole. I positioned the stainless ring on the tank after measuring 40 times and just screwed it down. I then took the pilot drill bit out of the big OL hole saw and used the ring for a guide. I cut the plastic in reverse because the saw would grab too much in forward. I knew the surface would not be level for my gasket to seal so I thought a heat gun should be able to soften the plastic and make it pliable enough to mold it back straight enough. I bent this trim tool to hold the plastic where I wanted it to be flatter. It worked. The trick was getting the plastic hot but not melting. It's just right when you begin to smell plastic.
Old 10-26-2025, 03:42 AM   #203
jjzepplin
jjzepplin's Avatar
You can see the divot and the couple places where the tank is not flat. I set the heat gun inside the tank and put the setting on high. I just unplugged it when I smelled plastic. I then put my tool under there and used a couple small pair of vice grip pliers to hold it. I just made sure they were no clamping hard at all, Just enough to bend the plastic. I think I can get a gasket to seal it up now.
Old 10-26-2025, 03:47 AM   #204
jjzepplin
jjzepplin's Avatar
So the bottom of the tank has this crud in it. WHT THE HECK is it? any suggestions on how to clean it out?
Old 10-26-2025, 03:51 AM   #205
jjzepplin
jjzepplin's Avatar
I am going to use the cut out piece to cut a round piece and plug the hole where the sender was. That will be tricky as I think I am going to cut a small area around the edge of it for the O ring. This is all a pain but should be cool when done. I am not doing anything else but training to be a Water Plant Manager. I manipulate Bacteria on a huge scale for a living now. THAT is very tricky business.
Old 10-26-2025, 04:27 AM   #206
jjzepplin
jjzepplin's Avatar
Well I did some looking and I think I am going to try some Chem Dip for carburetors to clean out the tank. I Have some in a gallon can. I will test it on a piece of the tank that I cut out.
Old 11-01-2025, 12:24 PM   #207
jjzepplin
jjzepplin's Avatar
Well I left a piece of the tank in the Chem Dip for w eek and nothing happened but it is very clean. I tried to go after this crud on the bottom of the tank before I Chem Dip it just to get the majority of the thicker stuff out. OMG! This stuff is crystalized and 1/8" deep in some spots! WHAT the heck is it? Tank Liner? Soft in some spots but not gooey.
Old 12-24-2025, 01:30 AM   #208
Prof
Do you still have the old 4x4 frame?
Prof is offline   Reply With Quote
Old 12-24-2025, 04:08 PM   #209
jjzepplin
jjzepplin's Avatar
I just sold the last piece of the original frame. A lot of guys on here wanted pieces of it. I bought another frame that is also a 4x4. It just has a 1973 up front cradle that is 2wd and still runs the leaf springs out back. I will probably end up 4 linking the rear when I bag it.
Old 03-11-2026, 03:28 AM   #210
jjzepplin
jjzepplin's Avatar
So this is the pile of crud I removed from the bottom of a plastic tank. Was it there all along or from the time that I owned it? Dunno. What's in the bottom of your tank? Maybe a pound or so...
Old 03-12-2026, 07:23 PM   #211
NDM
This is why I made my tank from Stainless steel. That is a whole lotta junk in there.
NDM is offline   Reply With Quote
Old 03-17-2026, 06:18 AM   #212
jjzepplin
jjzepplin's Avatar
This was in a used poly tank that I bought from someone here. I would have never known if I didn't cut a great big hole in it for a fuel injection pump. Imagine me scratchin my head for years wondering what is wrong with my truck. Now I am not sure if it was already in there or not. I did have my truck running very well with this tank before I decided to LS swap it. So maybe the new gas sitting in there with stabilizer for about 5 years did this. I routinely put new ethanol free gas in it and ran it through heat cycles as it sat there waiting for me to finish working on my house. I winder what is in my aftermarket 40 gallon tank? It is steel and that truck runs great!
