#201 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: 1971 K20- project just get driveable!!
The k20 is looking good and nice find on the parts truck.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#202 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Jud how's the rear bumper on the new parts truck? Looks like a cool and heavy period correct step bumper...good find on the parts C20.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#203 |
![]() Join Date: May 2013
Just read through the build.What a great truck.
I will be watching this and your others.You have some cool k20's. And its nice to see it used as a truck.! ![]() Tom |
#204 |
6>8 Plugless........
![]() Join Date: Sep 2007
Great work on the truck and nice score on the parts truck. It's in really nice shape. Can you go into more detail on the blower motor? I'm interested in this as I'd like to put the best one in mine before I actually make it a driver.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#205 | |||
Vintage 4x4s
![]() After this thing is on the road, I will resume working on the blue K20. Then I may do a quickie on the 71 K20 292 truck just to get it running again. Then work in a cummins conversion lol. Quote:
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#206 |
I would put the tube in it and point it down just to keep the water out. It would still get air to cool it.
#207 |
Carpe manana
Not looking for one but thanks for asking. I really like those old, thick steel step bumpers and have one painted and ready for my K20. I actually looked into having one chromed but was told by the plating co. that as mine had the diamond pattern on top the chrome wouldn't adhere well and would fail - too bad.
#208 | |
#209 | |
Vintage 4x4s
![]() I got quite a bit done on the truck this weekend. Pretty much didn't do anything else but work on it. Wire wrapped to keep new ducting on defrost vents: ![]() Decided to replace the poorly engineered original pump with something more modern: ![]() only bad thing is it loses the prime and has to be reprimed all the time. I think I will install a checkvalve or just look for a different pump. This one is technically supposed to mount directly to tank. Rebuilding the turn signal setup: ![]() Sig parts all cleaned up and ready to reinstall. I got a palmfull of dust out of the old one. Remember, this truck had no back window and sat in a field for a couple decades. ![]() Column (with new upper bearing) back in and radio delete and new cig tray installed: ![]() What? I have to fit this grommet over this speedo cable!!! Armor all (lube) and the vice to the rescue. I got it but it split the grommet a little. Next time, think I will just cut the grommet. ![]() Hood and different inner fender back on. That was fun by myself ![]() ![]() Getting real close, need to get shoulderbelts and put them in, hook up fuel sender and figure out why the dash lights are always on, then the seat can go back in. Also need to rebuild pass door mechanisms and put mirror on driver side. ![]()
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 02-19-2014 at 10:16 PM. |
#210 |
Great work! I always wondered if they put the grommet on before they crimped the cable ends on because they aren't real forgiving when you're trying to force that cable nut through that small hole.
#211 |
Nice work!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#212 |
Man, that truck is looking great what a difference from what it started from....
#213 |
Truck looks great.
Really like the look. Tom |
#214 |
Vintage 4x4s
Thanks guys, I ordered 2 of these and a lapbelt yesterday.
http://wescoperformance.stores.yahoo...t-gm-retr.html too cold here to heat the shop with propane these days, plus I've been wiring in the bathroom project.
#215 |
Thanks for that link. I need to measure my seat to floor on my truck and I will be ordering some of those. I've been waiting because the others I had seen on the net looked cheesy IMO.
#216 |
The set I bought thru a local vender didn't have a plastic housing on the inside belt. Its almost a two handed job to get it buckled trying to hold the inner buckle. If you can get a set with a plastic sleeve on the inner buckle side I would recommend it.
#217 |
Thanks for the link Vintage.
The belts look really nice and 29 colors.! Tom |
#218 |
Vintage 4x4s
Belts showed up. Should have some time to work a little on the truck this weekend.
Thinking I need to: -Install belts -Replace front rotors and calipers (never did since debating what front axle to run) -Check valve in wash fluid line -Install seat -Install rebuilt Qjet -Hook up gas gauge
#219 |
GEARHEAD
Looking real good. I think I still need to get my windshield washer working. Kind of forgot about that. And my wipers squeak real bad too. Looks like I found a couple things to keep busy on until I can get it back on the road.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#220 |
Vintage 4x4s
Well with the big rear bumper and lift, I need to drop the hitch a little and create a custom bracket to mount it. I used the software we use at work for design (Solidworks). I'm going to weld or bolt one of these on each side. Also checked the stress at the rear bolt, which would be the highest loaded. Its not exactly detailed to the proper degree but this simplified simulation is telling me its still not exceeding the material strength (31,000 yield for mild steel), even assuming 3000 lbs is reacted on that one bolt with a little washer. The real washer will be thicker and have more area.
#221 |
GEARHEAD
Looks easy enough to build. No way will it see that kind of force all downward like that outside of an accident. It would have to be 6000 lbs downward total because you have 2 sides. And pulling force would be shared across the other 2 bolts of each side, so it should handle anything the truck is capable of pulling. It actually looks a lot like the hitch set up I have on my Jimmy.
#222 |
Are you saying that with my 4" lift and 33" tires i may need to lower my hitch? I never thought much about that, can you tell me how high the bottom of the reciver hole is to the floor now and what you think would be ideal?
I do plan on buying a flatbed trailer and figured i'd need a drop hitch, but now i'm wondering if maybe there is not a drop hitch low enough. Any help appreciated.
#223 |
On these tall trucks, I've always wondered about the firce multiplier of the 4-6" drop drawbars. It's one thing to have the trailer's force in a nominally linear push/pull. Wonder how it works with a 4/6/8(!)" lever applied. Hitch looks good!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#224 | ||
Vintage 4x4s
[quote=swamp rat;6569959]Are you saying that with my 4" lift and 33" tires i may need to lower my hitch? I never thought much about that, can you tell me how high the bottom of the reciver hole is to the floor now and what you think would be ideal? I do plan on buying a flatbed trailer and figured i'd need a drop hitch, but now i'm wondering if maybe there is not a drop hitch low enough. On my factory tow package k2500hd, its about 16" to the bottom of the receiver hole and its worked really well for a straight hitch on big tandems and a mild drop on smaller trailers. You can definitely get away with a drop hitch if you arent hauling very heavy loads. I looked at your hitch and its not one of the strongest setups since the mount is the shorter frame interface. That said, the mfg rating is still probably quite high but would be reduced with a large drop hitch. the drop will not cause greater stress from the tongue weight of the trailer but will when braking due to the offset and resulting momen Quote:
wouldnt be too hard to calculate the load increase under hard braking. we could assume full deceleration in 4 seconds or so, then get ft/sec^2, then F=ma, then multiply that force by the drop distance (from frame bottom, not recvr), and divide by length of interface at frame. That will be the additional amount of force reacted by the bolts at the rear.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 03-14-2014 at 11:20 PM. |
#225 | |
My hitch is class IV if i use a load leveler its rated at 12,000/600 without 10,000/500 I'm hoping to be able to tow a 18' tandem flatbed with another 67-72 pickup on it Or even a 24' camp trailer. Actually looking at it i feel the hitch is stronger than the truck frame so have been a little concerned. So by adding the brackets your making do you feel that it is stronger than using a drop hitch? lets assume i needed a 4" drop and the brackets accomplish this drop. Hate to say it but i don't understand your formula
