Old 01-22-2017, 11:19 PM   #201
solidaxel
solidaxel's Avatar
Re: Mike's 50
Originally Posted by MIKESAD50 View Post
it is from Street & Performance but I guess they are out of business now.
Thanks, is it a swivel ?l
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-23-2017, 11:10 AM   #202
MIKESAD50
Re: Mike's 50
Yes it is a swivel housing. seems to be a nice piece.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 01-27-2017, 07:17 PM   #203
solidaxel
solidaxel's Avatar
Re: Mike's 50
I found a swivel housing but the square "O" ring on the 86* factory thermostat is not cooperating with the recess in the housing.
Did the one you bought from S & P come with a O ring and did everything seal up OK?
LS 3 4L70E
Old 01-27-2017, 07:22 PM   #204
MIKESAD50
Re: Mike's 50
That was a couple years ago, and has not had any coolant yet.
I will try and remember to remove it tomorrow and see how its sealed. i seem to remember a problem with the thermostat and think I got a new one i will look thru receipts also
1950 3100 5 window
Old 01-28-2017, 01:37 PM   #205
solidaxel
solidaxel's Avatar
Re: Mike's 50
Thanks for the help, but
If yours is sealed up I would not open it up
LS 3 4L70E
Old 01-28-2017, 02:19 PM   #206
MIKESAD50
Re: Mike's 50
Yeah I didnt make it to the shop today, thinking I might try tomorrow.
Looking thru receipts I only found the one from Street & performance, and did not find a receipt for thermostat.
I did find a swivel thermostat I bought from Summit that didn't fit and was returned
1950 3100 5 window
Old 01-29-2017, 10:24 PM   #207
MIKESAD50
Re: Mike's 50
Made it to the shop for a bit today
I got the drivers door installed, need more adjustment and finishing.
I shortened the wiring for right side O2 sensor wiring.
Got my new windshields form Auto city, installed into new seals with the original trim.
I will try and install winshields.
1950 3100 5 window
Old 02-05-2017, 08:07 PM   #208
MIKESAD50
Re: Mike's 50
Well had an appointment with glass guy for Saturday and he didn't show up so windshield did not get installed.
I did get the throttle pedal installed, shortened the wiring to the pedal and finished it up. Got a spot for mounting the OBDII connector, under dash to the left of column. I didnt get pictures but will post some tomorrow.
I also got the underside of the front fenders cleaned up ready for a Por 15 coat, same process that was used on bottom of cab will be used on underside of fenders front and rear.
1950 3100 5 window
Old 02-05-2017, 09:36 PM   #209
Advanced Design
Advanced Design's Avatar
Re: Mike's 50
Well bummer about the glass guy. Look forward to the pics Mike. If you can, please show the throttle pedal mounting...looking for ideas on mine.
Advanced Design is offline   Reply With Quote
Old 02-06-2017, 08:35 PM   #210
MIKESAD50
Re: Mike's 50
Advance Design,
Here are a few on the pedal mounting pictures. The pedal and bracket it is bolted to came from GM with the connect and cruise kit. I added about 1/2" of spacer on the upper left mount.
I also stole the mounting washers for the bolts from youngrodder, looks better on the firewall. wish I would have planned better and welded studs and brackets to firewall prior to painting. I think I will bond whatever I need to do in the future to limit holes. The wiring from ECM to pedal and OBDII connector runs up behind pedal. I'm going to have to reposition the brake pedal pad to the left for clearance
1950 3100 5 window
Old 02-06-2017, 09:08 PM   #211
Advanced Design
Re: Mike's 50
Excellent Mike, thank you! Scott was looking for this for his build too.
Old 02-06-2017, 11:29 PM   #212
Scott2
Re: Mike's 50
Yes I am! Thanks - this helps!
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 02-06-2017, 11:32 PM   #213
joedoh
joedoh's Avatar
Re: Mike's 50
try it on your own, its not even a 10 minute job by yourself! most of the time on mine was getting the glass fit in the rubber, thats done!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 02-10-2017, 09:46 PM   #214
MIKESAD50
Re: Mike's 50
I think I might try installing the windshield, Glass guy flaked again on Thursday.
Today I installed the windlace on the drivers door opening. not too bad.
I've been using mostly Steele Rubber products and seems to be good quality.
Hope to get some more done this weekend.
1950 3100 5 window
Old 02-10-2017, 11:48 PM   #215
Advanced Design
Re: Mike's 50
Good. It isn't difficult. Maybe an extra set of hands would be good.
Are you familiar with the cord / rope installation procedure?
Old 02-11-2017, 10:05 AM   #216
MIKESAD50
Re: Mike's 50
Adavance, I am familiar with the rope procedure, Not sure I've done it except help (watch) when a kid with dad.
I might wait a couple of weeks till he is here and see if he can help install it. I do have plenty of other stuff to do besides the windshield
1950 3100 5 window
Old 02-11-2017, 06:21 PM   #217
MIKESAD50
Re: Mike's 50
Just a few things done today, little odds and ends. Installed seat frame, Bought a headlight switch from Classic, installed. Worked on right door windlace, about half installed. Final clamp on fuel line at frame. here is another picture of the pedals, you can see I will have to move the brake pedal pad for some clearance.
A picture sitting in drivers seat.
1950 3100 5 window
Old 02-11-2017, 10:07 PM   #218
donandal
Re: Mike's 50
I watched the guys put my windshield in. They were
very experienced and made it look easy....
but there was three of them and they had a system
down pat.
Is your windlace the type that slides in the channel?
If so, what did you use for lube?
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 02-11-2017, 10:12 PM   #219
reaper71
reaper71's Avatar
Re: Mike's 50
I noticed you have a sued steering wheel,I just picked one up for a customer and when they drive it the dye comes off on their hands!
You may wan't to spray it with a sued sealer (water proof ) type of spray.
Just a heads up.
Mark.
reaper71 is offline   Reply With Quote
Old 02-12-2017, 10:07 AM   #220
MIKESAD50
Re: Mike's 50
Donandal,
yes the windlace is the type that goes in the channel. I put it in dry. When I started it on the drivers side used 3M Dry Silicone spray, but since I read often not good when it comes to any painting I didnt use it. It is a product we use often in the shop.
I used what we call a "Bone Tool" weatherstrip tool and just moved along at a slow pace. I didnt time it but I would think about 45min-1hr to install completely. I will get a picture today, I think I will head down to the again today.
Reaper, I never heard that before. Is that common or just certain ones? Do you have a brand of sealer? I havent had any thing coming off so far, but havent driven, just moving around.
1950 3100 5 window
Old 02-12-2017, 11:03 AM   #221
reaper71
reaper71's Avatar
Re: Mike's 50
I can't answer that for sure...I picked it up from Speedway. When I called them on it they pulled 3 more of the same brand and model and the same thing happened.
John (customer) used a furniture spray,not sure on the brand.
Mark.
Old 02-12-2017, 11:10 AM   #222
MIKESAD50
Re: Mike's 50
Might be a good thing if I havent got any thing off it so far, and Speedway got dye off it right off the shelf.
Mine was bought from Detroit Speed
1950 3100 5 window
Old 02-12-2017, 05:35 PM   #223
MIKESAD50
Re: Mike's 50
Here is the "bone tool" used, hard plastic and just using to push into channel, working well. I tried sliding seal into channel but it only worked on the back side or the door since it was straight and channel has to be in proper shape.
I got a coat of POR 15 on front fender undersides. cleaned up a rear fender
1950 3100 5 window
Old 02-12-2017, 06:08 PM   #224
donandal
Re: Mike's 50
Donandal,
thanks for the info,
I think I'll try it with a tool like that.
probably messy with any type of lube!
53 Chevy Pickup
Old 02-18-2017, 09:25 AM   #225
MIKESAD50
Re: Mike's 50
Well i think I'm going to head down to the shop today and play with the truck.
I got parts in for upper radiator hose, silicone 90* elbow, a 90* elbow that reduces from 1 1/2" to 1 1/4" in silicone also. then I got a 90* aluminum elbow. once i get everything cut I got a bead roller for the tubing. I will put up a picture of other pieces and a finished product of upper radiator hose.
I had my aluminum cut to size the other day for mounting electronics and fuse panel under seat. I need to get it mounted and along with electrics
1950 3100 5 window
