Old 02-03-2016, 02:32 PM   #201
tinydb84
tinydb84's Avatar
Re: Used Parts Build
I picked up some bad habits when I first started welding and the "mig like tig" was the cool thing. Once in awhile I walk out my spacing too much. It was one of the first things my welding instructor pointed out. Thanks for looking out.
David
Instagram: myfabguy
Old 02-08-2016, 12:49 AM   #202
tinydb84
tinydb84's Avatar
Well that was fun...
Got the back half welded in. Nice and warm weather but windy as hell. Got to hangout in my fort again!
weld shot
Everything burned in
Back half done
Still need to box the inside and fishplate the front half of the notch
David
Instagram: myfabguy
Old 02-12-2016, 01:21 PM   #203
tinydb84
tinydb84's Avatar
Did a little work last night. Wanted to fishplate my notch to frame tie in. Totally not necessary but I figured it couldn't hurt.
Capped the notch/frame
Started cutting the brackets off my Ford 9''. Looks like the guy who welded the tabs on last time thought more was better...All the tabs are 1/4'' thick and have huge multipass weld beads on there.
I noticed a potential problem too. I thought for some reason my pinion was centered, and its not... Not a huge deal but my four link mounts/crossmember is set up for a centered driveshaft. I can shorten one side but I pushed my lower link mounts out as far as I reasonably could for better control. I am going to take some measurements tomorrow and see how much I need to shorten one side to center it and see if I need to move my tabs in or not.
David
Instagram: myfabguy
Old 02-12-2016, 06:02 PM   #204
aggie91
I'm just glad to be here!
aggie91's Avatar
looks good. I have seen a lot of 9" rears done that the pinion is not centered, but the pumpkin is centered for looks...I think the pinion offset is less than 2"...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-12-2016, 07:35 PM   #205
tinydb84
tinydb84's Avatar
I would like to keep the pumpkin centered for looks. I need to check the driveshaft to see if it will clear the 4 link mount crossmember. I may set up my Panhard bar to have the pinion move towards center when it airs out if that's necessary to clear.
I'll have to do some mock up this weekend.
David
Instagram: myfabguy
Old 02-15-2016, 01:06 AM   #206
tinydb84
tinydb84's Avatar
Started stripping the Ford 9'':
Chopped off the last bit of frame to make it the length I needed:
Started mocking up my rearend and links to get a measurement:
Marked out when I am going to drop it into the frame:
Notched:
Mocking it up:
All welded in!
David
Instagram: myfabguy
Old 02-15-2016, 12:50 PM   #207
aggie91
aggie91's Avatar
Nice progress!
Karl
The LST Challenge:
Old 02-19-2016, 03:54 AM   #208
tinydb84
tinydb84's Avatar
Thanks Karl
Trying to chip away at it every chance I get.
Shot a quick coat of primer because it was going to rain.
Welded my lower tabs on the axle:
Still working on tig welding everything I can:
Going to box the backside and cut it to match the frame tabs. Hopefully will get the upper tabs and possibly the Panhard bar installed this weekend.
David
Instagram: myfabguy
Old 02-20-2016, 03:42 PM   #209
tinydb84
tinydb84's Avatar
Small update. Did a bit of welding last night.
Welded on some plate to box my links:
Practicing my weaving skills
Wanted to notch it to make match the crossmember tabs
Done!
David
Instagram: myfabguy
Old 02-20-2016, 04:30 PM   #210
68Timber
I know the pieces fit
68Timber's Avatar
Those welds look like art, wish I could weld like that. I don't think I've seen anyone kick the rear frame rails up like that. What are the benefits vs. keeping it at original height?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-20-2016, 05:00 PM   #211
tinydb84
tinydb84's Avatar
Thanks man. I have only been tig welding a few months. I just try to weld as often as I can. I am hoping to go to Hobarts welding school in the next few months and take their tig course to get better at it.
No real gain to keeping them high. I didnt want to shorten the frame and then notch it so I just moved the notches forward. The rest of the frame lost all the original mounting points so I figured Id just leave it high. I am going to build a cradle to bolt up underneath that will hold all my air ride and gas tank. That way I can unbolt it and drop it down if I ever need to instead of removing the bed.
David
Instagram: myfabguy
Old 02-22-2016, 03:02 AM   #212
tinydb84
tinydb84's Avatar
Today was just not my day....
Mocked up my rear end to lay out my upper tabs
Noticed that my notch didnt line up with the rearend as I measured....
Tossed on a bedside to see if my notch or if my 4 link crossmember was off
Well that sucked...I dont know where I went wrong...The only think I can think of is I measured off the wrong reference point when I was mocking up my crossmember.
So I moved the axle to see where everything should have been.
That black strip is primer so it doesnt rust.
So I proceeded to cut the crossmember out. Patched the frame and move it forward 4.5''. It was dark so I didnt get any pics. I'll be back at it tomorrow.
David
Instagram: myfabguy
Old 02-22-2016, 09:19 AM   #213
Joe Pass
Joe Pass's Avatar
That's a tuff one.....and frustrating. At least, you caught it now.
Joe Pass is offline   Reply With Quote
Old 02-22-2016, 10:14 AM   #214
jwilson645
Always a good idea to tack in and check that everything lines up BEFORE final welding.
jwilson645 is offline   Reply With Quote
Old 02-22-2016, 01:24 PM   #215
tinydb84
tinydb84's Avatar
That's what I'm telling myself!
I know....Ugh. Lesson learned!
David
Instagram: myfabguy
Old 02-22-2016, 01:44 PM   #216
DblTrbl
DblTrbl's Avatar
I know all about how that feels...
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 02-22-2016, 01:56 PM   #217
daddyjeep
daddyjeep's Avatar
That sucks, unfortunately that's part of the game when you are doing crazy things.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-22-2016, 03:16 PM   #218
tinydb84
tinydb84's Avatar
When I first saw it I thought the notch was wrong and said screw it and started looking at 2x4 steel to just to a new backhalf.
Everything measured so perfectly square I thought it was perfect. One step forward one step back? I'm more embarrassed than anything. Got more momentum on this project than I have had since I got it so I am not going to let it get to me!
David
Instagram: myfabguy
Old 02-22-2016, 03:49 PM   #219
68Timber
68Timber's Avatar
I wouldn't sweat it. That's a small setback at the rate you've been going.
John
74 Honda Z50 build
Old 02-22-2016, 10:10 PM   #220
tinydb84
tinydb84's Avatar
And fixed!
Need to clean up the inside of the frame still but at least everything is where it needs to be!
David
Instagram: myfabguy
Old 02-22-2016, 10:32 PM   #221
Joe Pass
Joe Pass's Avatar
Good your back on track....I thought I was going to have to return watching Street Outlaw re-runs....Saved
I will follow on Instagram also...
Joe
Old 02-22-2016, 10:45 PM   #222
daddyjeep
daddyjeep's Avatar
Glad you got it where it needs to be.
New Street New Orleans tonight. No need to watch reruns.
04 1500 crew cab
Old 02-23-2016, 06:51 PM   #223
tinydb84
tinydb84's Avatar
I don't think my build thread is that exciting but thanks haha
I was looking at my panhard bar and decided that I wanted something a bit cooler so I ordered this today:
Ordered it from All Day Fab. Seems to have good reviews. 1.5 diameter so it matches my other links and is all tig welded.
I am going to do floating bag cups for the upper mounts using matching 1.5'' tube to hold them in place. Hopefully it comes out cool.
David
Instagram: myfabguy
Old 02-24-2016, 04:05 AM   #224
tinydb84
tinydb84's Avatar
I hadn't planned on running a rear sway bar. Then after I started spiraling with the build I decided to do a spindled style bar. I had been putting off buying a rear sway bar because it seems whenever I buy something I don't end up using it forever. So I ordered this today too.
Got my upper tabs welded on
I need to figure out the boxing of them. I need to leave some section of the bottom open so they don't hold water. I have a few ideas going already.
And of course a weld shot
Thats all I got done before I ran out of argon. Man that **** goes fast compared to mig!
David
Instagram: myfabguy
Old 02-24-2016, 10:06 AM   #225
jwilson645
Are they pieces you cut or pre-fab? Most pre-fab brackets are already this way.
Just trim the bottom of the pieces into a U shape before welding (like the pieces you've already welded to the axle tube) . That'll leave a space for draining.
