Old 01-19-2018, 04:27 AM   #201
Jaysonb
Jaysonb's Avatar
Re: Dad's 1979 GMC Heavy Half Transformation
Just a very thin skim of filler will be all it takes to make this look perfect, and now the rocker to door gap is nice.
Jaysonb is offline   Reply With Quote
Old 01-19-2018, 12:14 PM   #202
Dads79GMC
Dads79GMC's Avatar
I know what you're talking about! I could have sworn I took a picture of what you're talking about and can't find it. Looking most excellent!!
Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 01-19-2018, 05:25 PM   #203
rusty76
rusty76's Avatar
I’ll take your word for it. Looking good.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-01-2018, 12:28 AM   #204
Dads79GMC
Dads79GMC's Avatar
JaysonB sent me a text this morning on the progress of the passenger side body work. I think this side of the cab got the best of him, but, he was able to take some poor reproduction panels and turn them into a top-notch product. Good job Jayson! Thanks for all you're doing on Dad's truck. Thanks Mike
Old 02-01-2018, 02:11 PM   #205
Low Elco
Looks beddy beddy good!
Low Elco is offline   Reply With Quote
Old 02-06-2018, 04:03 AM   #206
Jaysonb
Jaysonb's Avatar
All the rust repair us done on the cab. Working on cleaning up the welds on the bottom of the cab, and double checking for pin holes in the welds. As soon as things are cleaned up on the cab, the body work should move along quickly. It was a chore to get things on the right side of the cab to cooperate, but I finely got things beat into submission. Now to try and squeeze myself back under the cab to get some work done.
Old 02-06-2018, 05:48 AM   #207
MrFinland
MrFinland's Avatar
Originally Posted by Jaysonb View Post
Now it's time to re-hang the door, and put the front fender on to see how things fit. The last 3 or 4 sets of rockers i have done, have been stamped kind of funny, sort of smiley face shaped when you look at the bottom door gap, and they have also left me with a big gap between the rocker and fender. I have bought them from diffrent vendors, ordered some in town here, and everything I find is the same. So this is what I have come up with to make the fit acceptable. The front edge of the rocker got a vertical slice, and the end moved forward about 1/4" to close up the big gap from the fender to rocker, and when you move the front forward, it also comes out a little, fixing the leading edge of the smiley face at the same time as closing the gap. To fix the rear end what I have done is sliced along the length of the rocker, and down next to the cab corner, closed the door, and moved it to make the bottom door gap even. It is a bunch of work, but worth it in the long run.
Hello Jason! I just had a similar problem with our truck. But now it looks good on your repair.
MrFinland is offline   Reply With Quote
Old 02-06-2018, 07:00 AM   #208
Jaysonb
Jaysonb's Avatar
It's weird how things can fit easy on one side, and you can end up with your hands full on the other side! That's why it's so important to keep checking the fitment of everything as you go along. As soon as I finish up the first round of body work on the cab, I will put the truck back together one more time, that way I don't end up with any unwanted surprises once it's painted. I got the welds cleaned up under the cab, and I like to put a tight skim coat of fiberglass reinforced filler over the welds. It's waterproof, so if I missed any pin holes I will be ok, and after a quick sanding, priming, and undercoating, the repair will be pretty much invisible.
Old 02-06-2018, 02:37 PM   #209
Dads79GMC
Dads79GMC's Avatar
Looks great Boss!!
Old 02-16-2018, 11:30 PM   #210
Jaysonb
Jaysonb's Avatar
Now that the metal work on the cab is done, I put the truck back together, and got stuff adjusted so I don't end up with any surprises putting it together once it's painted. Things ended up fitting very good!
Old 02-24-2018, 06:24 PM   #211
Dads79GMC
Dads79GMC's Avatar
Couldn't help myself, JaysonB sent me these early this morning!!! Looking great Jayson!!!!! Epoxy.
Thanks Mike
Old 02-28-2018, 03:10 PM   #212
Low Elco
Go JAyson Go!
Old 03-08-2018, 01:35 AM   #213
Dads79GMC
Dads79GMC's Avatar
Originally Posted by Low Elco View Post
Go JAyson Go!
Yes, go Jayson go!!!!
Old 03-20-2018, 06:27 AM   #214
Jaysonb
Jaysonb's Avatar
It's been awhile since I have updated on my progress. The last time I test fit everything, the passenger side just seemed a little off all the way around, so I have had to spend some time reworking the front of the rocker/door hinge piller area. At some point this area was pushed in a little, and it took me awhile to track down the area that was causing me trouble, because there was no obvious damage anywhere. I was running out of adjustment in the door hinges, and was barely able to get the body line on the door to match up with the body line on the cab. So I had to take a step back and figure out what was going on! Once the bottom of the hinge piller was pushed back out about an inch, it put the door hinges right in the middle of the adjustment range, and made things fit better overall! I did have to cut the front half of the rocker loose, and get it lined back up with everything, but it all fits good now. Now I'm getting after sanding the cab, it is in slick sand now, and I have the first round of block sanding about done. Pic 1 shows how things line up after getting everything straightened out. Pic 2 shows how far I had to come down after I pushed the piller out an inch. I had the paint mixed up, looks good! I'm hoping the pace will pick up now that I have things fitting good!
Old 03-20-2018, 08:56 AM   #215
aggie91
I'm just glad to be here!
aggie91's Avatar
That color is going to look outstanding on this truck.
When you say you pulled out the hinge pillar area, is that out from the center? or forward? Besides the rocker but you showed above, what else was cut loose? Just trying to wrap my head around what you did to fix the alignment issues.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-20-2018, 09:15 AM   #216
Dads79GMC
Dads79GMC's Avatar
Color is perfect Jayson!!!
Old 03-25-2018, 06:58 AM   #217
Jaysonb
Jaysonb's Avatar
Spent the night blocking out the cab, and working on the roof, there were a bunch of little dents, and dings up there. I believe that it is nice and straight now. With the next round of primer I will hit the inside of the cab, so I spent some time finishing up the floor, and hit it with a couple heavy coats dupont mastic epoxy, very tough stuff, and extremely corrosion resistant. My plan is to get some 2k high build primer surfacer on the cab this evening, then get the doors, fenders, and hood ready!
Old 03-25-2018, 07:12 AM   #218
Jaysonb
Jaysonb's Avatar
A little extra care, and time spent on installing the floor pans resulted in an almost undetectable repair. It's the little things that make my OCD happy.
Old 03-25-2018, 07:38 AM   #219
MrFinland
MrFinland's Avatar
Very well done, Jayson! I like it very much, when it looks like a factory made.
Old 03-25-2018, 07:50 AM   #220
Jaysonb
Jaysonb's Avatar
Thank you Ilkka, it's trucks like yours that motivate people to try and go the extra step to make things nice!
Old 03-25-2018, 08:19 AM   #221
MrFinland
MrFinland's Avatar
Thanks Jayson! I and my brother are beginners and we have to learn a lot, but you are a professional.
Old 03-25-2018, 10:38 AM   #222
palposity
palposity's Avatar
Great build!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 03-25-2018, 10:53 AM   #223
Dads79GMC
Dads79GMC's Avatar
Looks great Jayson! Can’t wait to see some color!
Old 03-25-2018, 08:32 PM   #224
rusty76
rusty76's Avatar
I’m late but are you using new sheet metal on the front like the hood and fenders? I’m just curious about the fit. Thanks. Looking good.
My build thread
Crossmembers CC
Old 03-25-2018, 09:04 PM   #225
Dads79GMC
Dads79GMC's Avatar
Everything up front is NOS. I’ll let Jayson describe how it fits. Mike
