#201 |
Re: New member with a 1960
1965 Olds 442 "Project Oldmobile" 1971 2wd GMC Jimmy..."The Orangutan" 1961 Apache "The Ape" http://67-72chevytrucks.com/vboard/s...d.php?t=679735 |
#202 |
Looks great!
Anybody have experience the longevity of clear over rust? .
65 C20 292 4spd 4:56 Eaton HO52 |
#203 |
Excellent question, we have been using a formula of baking soda and water to neutralize the rust process, before clearing but I cannot answer that! the raw amount of clear coated rat rods in existence is surely some testament of how it could possibly stand up, on the other hand I haven't heard any complaints about anyone having to re-clear coat their rat rods..... LOL now I am wondering .....
#204 |
#205 |
#206 |
Sometimes I read threads at other forums then my usual '47-'59 board.
Normally I just read, but this is something else! This is going to be an awesome truck! Page after page great enginering ![]() Fantastic build, I follow along, if you don't mind! Thanks!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#207 |
![]() ![]() Join Date: Aug 2013
This is crazy...lol....Lots of work...
#208 |
Thank you very much!
#209 |
Thanks Joe....I think...LOL
It should really help with the handling and body roll!
#210 |
The rear suspension is buttoned up minus shocks, we are waiting on some double adjustable Strange coil overs, I am not sure if I should run the lowering springs without the coil over springs, or just run the springs on the coil overs.
Earlier I had asked for some ideas for heat/AC vents, I really don't like the looks of the plastic vents that screw to the bottom of the dash.... So we came up with the below idea....... ![]() ![]() The back side (in the door jamb) had to be cut out and a fitting fabricated to attach to the AC/Heat duct hose up in the dash, the jamb area will then be welded back and smoothed out before painting the jambs, for the center I had a spare door that was the same color and had already been clear coated so we used that metal from the door panel to build the vent housing! ![]() ![]() ![]() ![]() ![]() ![]()
#211 |
#212 |
For those of you that have LS swapped your trucks, what are you using for a throttle pedal ?
#213 |
#214 |
wow that's cool (pun intended)
#215 |
Looks great, good use of that blank space
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#216 |
well thought out.....
#217 |
Thanks for all the compliments guys. I don't have any pics but the 1 piece power windows are now in and working! They were a bit of a pain but I think they will work fine for the longevity of the truck!
A friend put together a little video of the truck and progress. Click the link below! https://vimeo.com/187586186
#218 |
#219 |
Is that a magnetic brake by the shop door?
63 C10 65 Chevy Custom Cab w/ Big Back Window 66 C30 72 skylark w/ 454 65 K10 May the bridges I burn light the way.... ![]() |
#220 |
I wish I had done one peace windows after dealing with all the whether stripping of the regular ones.
#221 |
The only thing I didn't like is that they roll up crooked, not straight up and down like factory, that's the only way they will work correctly, it looks odd... very odd but works awesome!
#222 | |
Hows your truck coming?
#223 |
67cheby
![]() Join Date: Sep 2008
Nicely done, i dig that coolant tank!
#224 |
Those vents are awesome! Great idea and use of space, beauty
#225 |
Thanks guys. I love getting feedback!
