Old 08-31-2021, 10:26 PM   #1
Jason 56
Re: My 56 build
Trailered the truck back from the alignment shop today. Everything came out great They were just going to check to see if it could be aligned and it was looking good so they just tried to see how close they could get it. Turns out it aligned perfectly and I was told that it should drive great
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 09-10-2021, 11:20 PM   #2
Jason 56
Re: My 56 build
Installed a one piece power window kit. I need to obtain the seals to confirm the shape of my templet. Otherwise the install was easy. Hopefully they seal nicely.
Old 09-10-2021, 11:22 PM   #3
Jason 56
Re: My 56 build
Received my exhaust kit today. This is the next project.
Old 08-25-2021, 12:07 PM   #4
Kermitt47
Kermitt47's Avatar
Re: My 56 build
Congrats! That is a Big deal to go from a pile of parts and ideas to a running, driving machine. Everything else is icing on the cake.
Kermitt's 47 truck build
Kermitt47 is offline   Reply With Quote
Old 08-26-2021, 07:42 AM   #5
6DoF
6DoF's Avatar
Re: My 56 build
NICE! that's a huge moment!
6DoF is offline   Reply With Quote
Old 08-26-2021, 11:33 PM   #6
Jason 56
Re: My 56 build
Thanks everyone. I’m hoping it doesn’t rain tomorrow. I’m putting it on the trailer to bring it to be aligned. We’ll see. It’s forecasted to rain all day.
Old 09-11-2021, 10:26 AM   #7
mrbuck
Re: My 56 build
Man, it’s really coming along ����
What one piece window kit did you use? Is it power window?
mrbuck is offline   Reply With Quote
Old 09-12-2021, 10:05 PM   #8
Jason 56
Re: My 56 build
They are made by specialty power windows. They’re made in Georgia. Little expensive, but the quality is there. Yes they are power. The only thing I don’t care for are the 80’s style window controls the kit comes with. I’ll be changing those. Here’s a link to classic parts where I bought them.
https://www.classicparts.com/1955-59...tinfo/18-766B/
Old 09-12-2021, 10:09 PM   #9
Jason 56
Re: My 56 build
Here’s a start to the crossover. I’m still waiting for my mufflers to see where everything falls.
Old 09-14-2021, 10:09 PM   #10
Jason 56
Re: My 56 build
Spent most of the day today knocking out the exhaust. Mufflers were delivered around noon and hours later… an exhaust. The kit I used was 2.5” mild steel and a pair of borla mufflers. It sounds good Here’s a bunch of pictures.
Old 09-14-2021, 10:16 PM   #11
Jason 56
Re: My 56 build
A few more pictures. I decided to have the exhaust exit the rear fender. I plan on cutting the exhaust flush with the fender and the paper ring will be chrome… maybe.
Old 09-15-2021, 09:48 AM   #12
Rickysnickers
Rickysnickers's Avatar
Re: My 56 build
Looks great, and the pictures are turned the right way!! Thank you for posting!!!
Old 09-15-2021, 12:39 PM   #13
bosco
bosco's Avatar
Re: My 56 build
Great work on the exhaust. Really like the exit.
bosco is offline   Reply With Quote
Old 09-15-2021, 11:16 PM   #14
Jason 56
Re: My 56 build
Thanks, I have even figured out how to edit and rotate pictures now
Thanks, I’ve only seen that exit on a few trucks and really like the look.
Old 09-16-2021, 10:13 AM   #15
Rickysnickers
Re: My 56 build
WOOOOHOOOO!!!
Old 11-20-2021, 03:35 PM   #16
Jason 56
Re: My 56 build
I had a sway bar delivered and mounted. It was for a tri-five car. I bought it from speedway. Fits like it was made for the truck. Also spent a lot of the summer trying to get the power steering working. After a lot of grief I finally came to the conclusion that the new pump I bought was defective. I even tried to adjust the pressure with a kit I bought. The original reservoir I bought didn’t have a baffle either, so I bought another one. It seems to ok now, but time will tell.
Old 11-21-2021, 11:21 AM   #17
Rickysnickers
Re: My 56 build
On the sway bar, do you have a part number for that, or anything? It might help some others down the line.
Old 11-21-2021, 07:47 PM   #18
Jason 56
Re: My 56 build
Here’s the link for speedway:
https://www.speedwaymotors.com/Speed...nch,99701.html
Old 11-27-2021, 09:17 AM   #19
mrbuck
Re: My 56 build
What brand front end did you use? I’ve got a Heidts and wonder if that sway bar would still fit.
Bucks build thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=825476
Old 11-27-2021, 09:50 AM   #20
Jason 56
Re: My 56 build
It’s a helix kit. I would think it should fit. You’ll have to weld mounting points on the a-arms as I did.
Old 12-08-2021, 08:32 AM   #21
Jason 56
Re: My 56 build
Finished the passenger seat yesterday. You may notice the backs aren’t at the same height. The passenger seat only slides forward and back. The drivers side has full range of movement and is at maximum height. So I can move that one down. Now that I know where they will live, I’m pulling the interior back apart to do the dash n vintage air. I have the week off so I should make some progress. Heat will be running in the garage today. It -13 here this morning… brrrr!
Old 12-08-2021, 10:04 PM   #22
Jason 56
Re: My 56 build
Today’s progress… got the vintage air box hung. Modified the bracket and welded bolts to the inside of the firewall. Also sectioned the dash. I’m going to add 3” to is so I don’t need a filler plate on the bottom. Now I’m trying to figure out how to run the lines through the lower passenger cowl and along the outside of the inner fender. The lines in the last picture aren’t going to work. I’m trying to keep the engine compartment clean. I’m installing the condenser tomorrow.
Old 12-09-2021, 08:24 PM   #23
Kevin_C
Re: My 56 build
Looking good. Can't wait to see what the dash looks like extended. I was surprised how little room there was when I installed the my evaporator. I had already smoothed my firewall so I just welded the bracket to it.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 12-09-2021, 11:01 PM   #24
Jason 56
Re: My 56 build
Got the condenser installed today. Of course it had to be modified because of my radiator setup, but everything fits well. I also changed the way I hung the evaporator under the dash. I remembered barnfind62 mentioning using a french cleat (with slammed57’s recommendation) to hang the top so it can be removed. Thanks to both of them for the idea. I’m going to eliminate my glove box so I won’t be able to get to the top. I’m also planning on eliminating the rectangular vents that would hang below the dash. Going with 2 more round vents instead. Off to order an ac hose kit n crimp tool. You can tell you’re not in hot rod country when you call every garage n parts store and no one has one I can use.
Old 12-10-2021, 08:34 AM   #25
Father&son56project
Re: My 56 build
Nice progress! I had to look up what a "french cleat" was, and once I saw it I realized how handy that can be for unreachable spots. I am adding that idea to my bag of tricks for the future. I'm looking forward to pics of that dash extension.
Father&son56project is offline   Reply With Quote
