12-09-2021, 10:40 AM | #201 |
Re: 1950 Chevy 3600 Woody R
so today was all about getting the engine ready to run
we cleaned and installed the valley cover and knock sensor harness Then we construct an AN line and installed AN adapters for the high pressure power steering line And we installed the ETC
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
12-09-2021, 11:49 AM | #202 |
Chris, looking good...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
12-09-2021, 01:51 PM | #203 |
Thanks Jim
12-09-2021, 10:41 PM | #204 |
Today we spent the majority of the day working on the mustang, but we did find time to pull apart the exhaust and seam weld it.
We also straightened out the muffler That is brand new pipe, just weathered. We can spruce it up for you though We also painted the tank, Tomorrow we’ll work on building the fuel system
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-10-2021 at 11:00 AM. |
12-10-2021, 08:59 AM | #205 |
Moving right along now.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
12-11-2021, 10:01 AM | #206 |
This is not my mock-up
But rather your actual Vintage Air evaporator installed we started building the fuel system, but are at a standstill. I had to order parts
12-13-2021, 09:48 PM | #207 |
The first thing we did is fix the exhaust, the crossover was to far back and wouldn’t let us put the transmission yoke in
Then we had Dheil tire bend up some 2.5” tailpipes to our specifications The end of the frame needs to be trimmed once we get the box on The harness had EV1 (car) injector plugs on it, they needed to be changed to delphi (truck) The EV1s are much taller, we tried them but the crossover tube for the fuel rail was to high and interfered with the engine cover
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-16-2021 at 09:13 PM. |
12-13-2021, 09:51 PM | #208 |
We drilled and tapped the water pump for the steam tubes
Installed both the oil pressure and water temp senders we had to buy a brand new starter, I didn’t have one that worked. We also installed the torque converter bolts And we built an engine ground
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-16-2021 at 09:14 PM. |
12-13-2021, 09:56 PM | #209 |
We installed the cover to be sure everything fit
And then put on the script for pictures
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-16-2021 at 09:18 PM. |
12-14-2021, 12:38 PM | #210 |
that cover came out great!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-14-2021, 09:01 PM | #211 |
we sanded down the passenger cowl
And continued to prep for initial start
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-16-2021 at 09:19 PM. |
12-15-2021, 09:11 AM | #212 |
Looking forward to seeing that cover between the fenders!
12-15-2021, 09:55 AM | #213 |
thanks
12-17-2021, 10:28 AM | #214 |
we did the rear shoes and wheel cylinders
Steven cleaned the transmission up we put the edge guard on the engine cover
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-17-2021 at 10:52 AM. |
12-17-2021, 10:30 AM | #215 |
we cut out the full length door panels out of waterproof cardboard
And installed the new fuel pump
12-17-2021, 06:54 PM | #216 |
Looking good. What did you have in mind after you clean up the pipes? I used Rust-Oleum barbecue paint on mine just to try it and I'm pretty happy with how it's holding up. The semi-gloss looks a little nicer than flat black header paint.
Fast, Cheap, Reliable. You may pick two My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723 |
12-17-2021, 07:04 PM | #217 |
Nice, I haven’t planned that far ahead yet
12-18-2021, 12:23 PM | #218 |
Cleaned up those outer cowls a bit
12-18-2021, 12:25 PM | #219 |
inished the fuel system , I was sick yesterday, so I didn’t go to work. On Monday I’ll decide if it’s ready for initial start up
12-18-2021, 12:49 PM | #220 |
a muffler shop I have used before simply uses aluminum spray paint. it stays on and also stays the same color. just don't spill gas on it cause it will come right off.
bbq paint seems the better choice and also comes in a few colors. keep posting, cool to see the progress pics. |
12-28-2021, 01:57 PM | #221 |
Moderator
With much sadness I would like to inform thread viewers that Chris Klapp aka "Skymangs" passed away on 12/23. There is a post in the main forum:
https://67-72chevytrucks.com/vboard/...d.php?t=829184
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
12-28-2021, 02:31 PM | #222 |
that is awful news.
Condolences to the family, he was very knowledgeable and always willing to help/share. I am sure there are many AD trucks back on the road today because of his help. RIP Skymangs
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
12-28-2021, 02:47 PM | #223 |
Thoughts and prayers to his family.
12-28-2021, 10:56 PM | #224 |
condolences to you and family
12-29-2021, 12:37 AM | #225 |
Condolences to his family, was a great guy, glad I had the opportunity to meet him...Jim
