01-10-2024, 06:33 PM | #201 |
Re: Tremec TKX 5 Speed Transmission Installation
Thanks for this thread, this is definitely on my list of things to do eventually.
Is your motor in the forward or rear mount position? To add to the swap info, if you have a newer bellhousing with the larger hole, you can use this adapter to reduce it, I used this on my manual 70 C10 to mount a Muncie M20 https://www.summitracing.com/parts/ADD-716078 |
01-10-2024, 06:35 PM | #202 |
01-10-2024, 11:03 PM | #203 |
Finished my install in the 6-banger position a couple weeks ago. The shifter clears the bench fine. Decided to make my own shifter and left it straight for now. I'll angle it to wherever is comfortable after I log some miles.
Thanks for the nice carpet. Mr. Patrick |
01-11-2024, 12:38 AM | #204 | |
01-11-2024, 09:12 AM | #205 |
Loving it from what I can tell so far. I've only driven it about 25 miles. I haven't had it properly aligned since the front end rebuild and still waiting for my 3-point belts to arrive. 1st-4th have been awesome, I get a little antsy in 5th gear speeds. Unfortunately I have kissed a metal dash before, I'm not willing to risk it, till she's safe-ish. |
01-11-2024, 10:56 AM | #206 |
Flipped
01-11-2024, 12:41 PM | #207 |
01-11-2024, 07:30 PM | #208 |
09-28-2024, 01:00 PM | #209 |
I replaced the Race Tuning mid-shifter with one that Tremec recently started selling. It is a big improvement.
1) It has a much shorter throw 2) The centering springs are much stiffer which makes it way easier to shift from 2nd to 3rd 3) It incorporates a 5th-reverse shift inhibitor 4) It is half the price |
10-27-2024, 04:30 PM | #210 |
A guy with a truck
Hey PJ, thanks for the excellent write-up! Taking notes, specifically on your shifter stick and the new Tremec mid-shifter.
How are you liking the TKX? My TKO has to come out because 1) it’s whiny and I’m tired of hearing it complain, and 2) I beat on it until it broke something inside the bellhousing this morning. Im thinking about upgrading to a TKX or maybe Magnum while it’s out, curious what your experience has been like with your transmission, especially shift quality and noisy-ness (not my TKO’s strong suit). Thanks -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-27-2024, 06:15 PM | #211 | |
10-27-2024, 09:09 PM | #212 | |
I found this on the ShiftSST site: "TREMEC approves the following fluids for all of their 5 and 6-speed transmissions: TREMEC HP-MTF, Pennzoil Synchromesh, Dexron III/Mercon ATF (non-synthetic), and Mobil 1 ATF. We recommend the ATF fluid for break-in and the TREMEC or Pennzoil fluid thereafter." I bought Mobil 1 ATF for mine to start with and was planning on Synchromesh for later, but haven't filled it up yet. |
10-27-2024, 09:27 PM | #213 |
I am running ACDelco Synchromesh which is one of the fluids listed in the installation instructions from SST.
