05-28-2011, 01:10 AM | #2301 |
Re: What did you do to your truck today!
Over the last few days, I installed a new quick ratio steering box, new power steering pump and a set of March pulleys, oh, and a Zoops power steering pump bracket.
05-28-2011, 03:19 AM | #2302 |
I haven't got much work done on the K10, sorry guys. I got busy with a transmission swap in my Monte Carlo. Hope to get the SS all sanded down and primed this weekend, then back to the Blazer gas tank install
05-28-2011, 12:45 PM | #2303 |
Not Mine But A beauty
i havent done anything in over a year
68 Chevy Shortbed 454/400 2000 Chevrolet Camaro SS 6spd 2011 Silverado 5.3 6spd auto |
05-28-2011, 01:16 PM | #2304 |
Loaded a winter's worth of dead tree limbs, then proceeded to get stuck in the mud!
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
05-28-2011, 04:38 PM | #2305 |
replaced the driver's side window regulator.
05-28-2011, 05:38 PM | #2306 |
Replaced my hood hinges..No more headaches for me
Big Block Powered |
05-29-2011, 12:46 AM | #2307 |
Finally took the cab ALL the way off of my frame so I can start the body work. Got all of my pulleys shimmed and lined up. Stuffed my dip stick and tube in my transmission. Fell off a ladder. Cleaned up my garage.
05-29-2011, 02:10 AM | #2308 |
drove it for the first time !!!! what a thrill !!!
05-29-2011, 11:02 AM | #2309 |
Finished grinding smooth all the welds on my exhaust and then laid down my first coat of por-20 silver exhaust paint. Has to dry for 24hrs before second coat can go on.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
05-29-2011, 12:45 PM | #2310 |
86 Scottsdale
Got after it pretty good this weekend.Friday I put in the battery tray I bought from the board to replace what was left of my old one.
Then, this morning, I went inside the cab, and laid on my head and surgically repaired shoulder for an hour and a half changing out the damn stoplight switch. My hands just couldn't get up there to loosen the top nut to drop it out. Turns out my trucks PO had crossthreaded it. After about an hour of messing with it, I grabbed a pair of dikes and proceeded to cut at the old plastic until I could pull the bottom nut off. Once it was off I pushed the stump up through the hole and out. In the end I won. My brake lights now only come on if you're actually pushing on the pedal (). To treat myself after all that hard work, I took the 2 minutes to install the new park light lenses in the grill. |
05-29-2011, 06:20 PM | #2311 |
05-29-2011, 09:02 PM | #2312 |
Junior Member
Mounted the uhaul hitch on my 72 K5
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
05-30-2011, 10:08 AM | #2313 |
got around to putting my Slotted/drilled rotors on, calipers, shocks and brake hose to the frame. Here's some pics.
Today I'll be putting on the front tie rods, pitman arm, idler arm etc. |
05-30-2011, 07:37 PM | #2314 |
Took my bed off with an engine hoist by myself, cut off the cab corner and trimmed the floor so i can install the new floor edge once i blast and strip everything that didnt rust itself to death. rust sucks
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
05-30-2011, 08:02 PM | #2315 |
Replaced the turn signal due to adding a tilt steering column. Signals work, horn works, making progress slowly.
05-30-2011, 09:54 PM | #2316 |
Dismounted all the tires from the 70 and put them on my 83 (and vice-versa). Then I cleaned and rearranged the shop so I could fit & sorta work on both trucks. It's still crowded when the 83 is in there, but at least I can open both doors on the 83 and walk around the truck to do stuff.
05-30-2011, 10:05 PM | #2317 |
Mounted and wired my electric fans. I really hate wiring!!!
Big Block Powered |
05-30-2011, 11:44 PM | #2318 |
Worked on my Vintage Air installation......
I cut the hole for the center vent and assembled & installed the condenser/drier.
68 C10 - LWB, 327/TH400 (original 307) 75 Buick Century - Stage 1 455 |
05-31-2011, 01:23 AM | #2319 |
What year truck are you puttin' that Vintage Air in? How do you like it? Small or Big Block motor? Does everything fit as they say it will? Sorry for all of the questions.
05-31-2011, 03:43 AM | #2320 |
I bought an intake :-), carb, intake gaskets, radiator, hoses, and a thermostat oh and a good battery are all next on the list of "gettin her goin" parts, gotta do title work somewhere in the middle of that mess
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet 1994 Buick Roadmaster 1994 GMC Sonoma |
05-31-2011, 09:52 AM | #2321 | |
This is their latest offering for our trucks which is servo controlled. Will be interested to see how it works.
05-31-2011, 10:29 AM | #2322 |
Member
Made some under seat speaker boxes and installed some 6" x 9" speakers. Finished installing new radio and putting dash back together.
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
05-31-2011, 10:38 AM | #2323 |
yesterday..
replaced a throwout bearing and put in my rebuilt manual steering box.
1970 C10 LWB (Grandfather's Truck) 5.3 4L60E 2012 Victory Cross Country Touring I'm not wasting money on my truck/bike, I'm helping to rescue the economy one mod at a time. |
05-31-2011, 01:56 PM | #2324 |
The long memorial weekend was productive...I swapped out my alternator to a 1-wire, byrassed ext. regulator. I also prepped and painted my new to me edelbrock intake, installed it and a new 1411 carb.
71 Chevy C-20 Fleetside Stock 402 BB-Summit Headers-700R4 Trans Dual 40 series flowmaster w/ H pipe Edelbrock 2161 intake & 1411 Carb |
05-31-2011, 08:23 PM | #2325 |
Well I Finely Broke down and had to Sale my Truck.
LOL Yeah right to that. I have to much invested into this one to sale lol. any how I did good yesturday Finely Sold the Donor I got the Bed and Frame and some other parts off of. and the good news is I fixed it back up decent enough to sale for just around the same price I purchased it for and saved a donor instead of trashing it. so I think I gained in this project just under 3k so now the good thing will be that money will go directly into this project to get it on the road this summer i hope..yay I am stoked!
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
