#2376 |
SSN 706
Re: Daverods project 66
Looking around my garage what did I see. A nice sandblasted and painted 66 manual steering box. Most important it was very tight. 15 minutes later it was on my 64. I forgot I had it I thought I chucked it. Steering is 100% better. Still have a off balance issue coming from the rear. Went to swap my tires I can't get my rear tires off without taking my bed off.?? I think I'm going to rotate my driveline 180 degrees and see if that helps. Then I'll swap my tires.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-28-2011 at 12:15 AM. |
#2377 |
1 thing at a time is progress.
Getting my rear tires off with a 72 rearend is a challenge. It's 3/4" wider on both sides and a 4" drop it's nearly impossible.
Alan
Philippians 2:14-16 |
#2378 |
SSN 706
Messed with my drive line. Figured out I can't rotate it 180. It's a two piece, it only works one way. I did notice the the u joint was'nt seated very good it had a big notch out of it. Moved my carrier bearing around alittle. You can really move it much. Went for a test drive.What ever I did it's much better now steady as a rock till about 80. Good enough for me. All my driving is in town.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-27-2011 at 11:10 PM. |
#2379 |
Resistance is Futile
Dave, are your tires stuck in the rear fenders?? I have to use at least 2 jacks and jack up the frame and the rear axle at the same time. Once the wheel is loose you have to let the rear down until the tire just squeezes out. Sometimes at about a 45* angle. It's a pain. I have 295's on my 'burb.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#2380 |
SSN 706
I jacked the axle up, put stands under the frame and let the axle hang. Then I unbolted the wheels and tried to take them off. No go. I did'nt try jacking the other side of the axle up. Maybe tomorrow.
#2381 |
Same here. I'm going to take off a 1/2" of the fender lip to make it easier. That or roll it under. There's about 1 1/2" of lip so 1/2" shouldn't make a difference as long as the braces are still welded.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
#2382 |
SSN 706
There you go. A little cutting.
#2383 |
i wonder how hard it would be to make the bed a dumpstyle bed , hinges on the back a locking device (treaded rod a big ring and a wingnut through the bedfloor maibe ?) and airbag to lift it ...... done
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#2384 |
SSN 706
I'm thinking these are going to catch on.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-28-2011 at 11:57 PM. |
#2385 |
Member of the longbed union.
They already make 4-5-6 kits. They look really retarted!
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#2386 |
SSN 706
#2387 |
Ever get your wheels off??
#2388 |
SSN 706
not yet worked on my 52. maybe this weekend. I'm hoping if I trim the metal I'll be able to get them off. Now I know why some people have fancy dump beds.
#2389 |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-10-2011 at 12:43 AM. |
#2390 |
HOW long until spring??
![]() Join Date: Mar 2009
Looks like your PS pump could be farther back to line up better with the back pulley on the crank . How does the alternator line up??
mine has the belt on the crank back slot , water pump and the PS pump. The alternator drives from the front slot on the crank and the front slot on the water pump. Use a straight edge or a wood board to line things up. I will clamp a board to a pulley if I am fabbing up brackets and want to stay in alignment.
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 04-10-2011 at 12:56 AM. Reason: added text |
#2391 |
SSN 706
Its back as far as it goes.Alt. lines up with front grove. The power steering pump has a rear bracket that mounts to the motor mount. It's were it needs to be.??? More head scratching.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-10-2011 at 01:05 AM. |
#2392 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The problem is that you have a power steering pump and brackets for the shor water pump. Your engine has the long water pump, and the alternator is of course in position for the long water pump. You'll need to get a PS pump for a long water pump application....'73 and up truck, or '69 and up car. With the long water pump, the PS pump hangs from the water pump from that boss below the lower bolt. Then there are brackets that bolt to the front of the head, and over to the front header bolt. There are some variations to that, but that is the basics. Probably best if you could get everything from a donor vehicle.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-10-2011 at 01:05 AM. |
#2393 |
SSN 706
I also have this pump but I couldn't figure out how to hang it. I had two different engines and things kinda got mixed up. I'll try again in the morning. Hope you have some of those brackets made Capt time gettin closer.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-10-2011 at 01:14 AM. |
#2394 |
Bungee cord???
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#2395 |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-10-2011 at 01:30 AM. |
#2396 |
I didn't read all the replies before I answered .you already had the answer
ron Last edited by padresag; 04-10-2011 at 05:15 PM. |
#2397 |
Hey Dave, I had the same problem when lining up my pulleys. I went to an old junk yard and took all the pulleys off a 283 truck that looked origional and got home and they didnt line up on my motor. I bought some shims off ebay to set the crank pulleys out about 1/8 inch and then eveything lined up perfect. I can get you some pics if you want.
#2399 |
SSN 706
You are the man.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-10-2011 at 10:18 PM. |
#2400 |
SSN 706
10 boxes an a hour later. wola
