01-11-2011, 10:37 PM | #2376 |
Re: What did you do to your truck today?
rebuilt a gmc grille. all new hardware, retaining rings, and headlights
01-12-2011, 12:12 AM | #2377 |
Sunday: Pulled the crappy seat out that came with the truck. Removed the jerry-rigged speaker box out. Tried to mount the new seat to the stock brackets but needed some flat bar to make adapters so will git er dun next weekend. Found a 1/2" wrench, kitchen knife, 2005 high school football schdule, a pay stub and two packs of rolling papers under the seat.
01-12-2011, 12:24 AM | #2378 |
Hell yeah!!!
finally brought mine home after having it sit at my brothers house. went needing some work came back in primer and a little lower.
Stock is good but custom is the sh*t! |
01-12-2011, 12:47 AM | #2379 |
I put in the bench seat so I could sit in there and make "vroom vroom" noises... does that count? If not I worked on fabbing my motor mounts. Putting a 250 where the 235 used to be.
Posted via Mobile Device Posted via Mobile Device |
01-12-2011, 02:07 AM | #2380 |
CLASSIX Truck Club
01-12-2011, 04:12 AM | #2381 | |
fan of "Butters" Stotch
I had a set on a previous car, and sounds like I may have a deal worked out with the new owner to trade them back
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again |
01-12-2011, 03:13 PM | #2382 |
Pulled the engine back out!!!! as the builder used too long of a bolt on the balancer and it was not tight. Thus I have one huge POS... Starting over bought a 400 block and I get to reuse my heads intake and carb, headers, valve covers and oil pan. The rest is wiped out. Crank had .018 thrust, it took out the rods, pistons, Crank..well it had a craked key way so it was junk already. Block was not 30 over but 60 over.. He is out of biz and no one can find him..
01-12-2011, 03:15 PM | #2383 |
Who Me?
I have my truck off the road for a few weeks to get some stuff done.
The battery is being relocated under the bed on the passenger side. I got the box built for it last night and hope to install it tonight and wire it up.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
01-12-2011, 06:57 PM | #2384 |
put in my new tilt column tommorow steering wheel and hook up electrical. the steering wheel is a red mettalic wheel from mooneyes
01-13-2011, 04:05 PM | #2385 |
Pretty much finished the chasis, starting on the cab now, cleaning the bottom on the outside, will sandblast tomorrow, then will work on the floor on the inside, will repair rusted out places. POR-15 it then undercoat it next weekkkkk
http://kieth.smugmug.com/Trucks/66-G...55794128_yZNmN |
01-13-2011, 09:15 PM | #2386 |
here are pictures of new column and steering wheel
01-13-2011, 09:21 PM | #2387 |
Hell yeah!!!
i like the it gimmy
01-13-2011, 09:22 PM | #2388 |
CLASSIX Truck Club
Man that wheel looks good. Is that a Lokar shifter?
01-14-2011, 11:07 AM | #2389 |
Started working on the cab top and bottom of floor, rust is not too bad.......stuck the black bed wood in the bed just to see how it was going to look.....Kieth
http://kieth.smugmug.com/Trucks/66-G...56429338_SNvTB |
01-14-2011, 12:59 PM | #2390 |
took the heater core off and started to clean it out.......hmm do you think this is why the heater did not work ??
http://kieth.smugmug.com/Trucks/66-G...56508564_UKF6o |
01-14-2011, 01:09 PM | #2391 | |
Resistance is Futile
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
01-14-2011, 02:02 PM | #2392 |
1965 Chevy C10, 2005 4.8L/4l60
naaaahhhhh, looks clean to me!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-14-2011, 02:51 PM | #2393 |
Lokar 23 inch shifter, mooneyes steering wheel
01-14-2011, 03:23 PM | #2394 |
Blew out the left front wheel cylinder and creeped it home with no brakes.
01-14-2011, 04:33 PM | #2395 |
Senior Enthusiast
Welcome to the forum. The good news being you made it home.
01-14-2011, 06:05 PM | #2396 |
I bought my truck back from a friend today after trading it to him for a '72 Harley project about a year ago. It's in a million pieces but it's actually in better shape than when I traded it! haha
01-14-2011, 08:53 PM | #2397 |
Senior Enthusiast
Fabricated and installed brackets moving the fog lights 1 ¾” forward and down ½”. They had been mounted on top of the bumper, nearly in contact with the G & C grille letters. This blocked the view of the letters and made it difficult to clean the letters and the lamps. The new position also makes the lamps look more “important”. The brackets also permanently align the elevation, allowing deletion of the adjusting swivels. To properly align now all they need is left to right positioning. The best part was the project only cost $1.68 for some new nuts and bolts.
Here are a few before and after shots: Before After Before After |
01-16-2011, 04:13 PM | #2398 |
Just got back from the painter and he has the clear shot on the upper sections of the cab and dash. We're getting close boys!! The finish will be semi-gloss, the clear was still wet.
http://s1299.photobucket.com/user/jb...23904108567829 |
01-16-2011, 04:22 PM | #2399 |
Senior Enthusiast
It looks beautiful in high gloss as well!
01-16-2011, 04:29 PM | #2400 |
Bought a split bench seat off of craigslist. My bench is shot, needs new foam and a cover, which would cost more than the truck itself did, so I'm gonna use this one. Upholstery and foam are good it seems to be pretty comfy, almost as comfy as the the fact I got it for 20 bucks!
1982 K10 SWB 1987 V20 - Sold - Doh! |
