#2401 |
HOW long until spring??
![]() Join Date: Mar 2009
Re: Daverods project 66
lookey what was at the swap meet at Firebird With an Impala dash no less !! Dave--- you are not gonna have the only one!!!!!!!!!!!!!! The chop top did not impress me at all,I am too tall and a low roof to hit my head on would just P^;SS me off.
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 04-12-2011 at 11:47 PM. |
#2402 |
SSN 706
Another unfinished project.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-12-2011 at 11:51 PM. |
#2403 |
Swap meets are where unfinished projects are passed on to others.
Who just might not finish them either!! ![]()
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#2404 | |
My uncle spent two days there and did not see it all. He said he was not looking at every booth either . It is supposed to be Huge!! ![]()
#2405 |
SSN 706
When is that?
#2406 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
It was a couple of weeks ago. I think they still have one in the Fall, but I don't think it is as big as the one in the Spring.
#2407 | |
60-66 Nut
I think that truck belongs to a member here.....can't remember his name ATM.
#2408 |
Daring to be Different
You guys forgot about Allan. He has a 59 dash also.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#2409 |
SSN 706
Allan?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-13-2011 at 10:32 PM. |
#2410 |
I have an extra gauge console for a 57 Chevy Belair. I wonder if I could make it work in my 65 dash. Do ya think it can be done.?
#2411 |
SSN 706
You can do it. Dare to be different.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-13-2011 at 10:26 PM. |
#2412 |
I'm just glad to be here!
Dave
I am doing the same thing with the brackets. Look closely at the picture on post 2398. There is a small spacer between the bracket and the head. Those 2 holes should line up. In your last picture the hole in the bracket should line up with the front header bolt (they should line up if the top ofthe bracket lines up with the hole in the front of the head). You will need a spacer between the header and the bracket since the stock manifold is much thicker in that area. You could use a threaded stud in the head for the header bolt that is long enough to pass thru the bracket. At the header, use a nut and then another nut on the stud on the backside of the bracket, then another nut to clamp the bracket down tight. Hope that makes sense.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#2413 |
Member of the longbed union.
You need to have a little spacer between the head and mount. There is a metal peice that goes between the exhaust flange and the mount.
For like $50 you can get a new mount off summit that's a lot better.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#2414 |
SSN 706
Where? Show me the money.
#2415 | |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-13-2011 at 10:44 PM. |
#2416 | |
#2417 |
Hey Daverod,
I did the same thing the pics are on my budget build. First page #23,24,25. Hope that will help. The build is looking good and am enjoying the fat fender build too. Keep up the good work! |
#2418 |
SSN 706
Thanks Spud. I think I have it all figured out finally.
#2419 |
A320 Pilot/USAF Retired
I know I've seen that 59 dash some where, just can't put my finger on it!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#2420 |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-14-2011 at 09:12 PM. |
#2421 |
I'm glad that your grinding skills have got better.
#2422 |
Hey you ran away without saying good by.
#2423 |
SSN 706
#2424 |
I thought I had the pic of your welding that you did, and I thought that was it when I posted it. I went back over to your thread.
#2425 |
SSN 706
You did'nt expect me to leave that on there did u.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-15-2011 at 12:12 AM. |
