Old 04-01-2011, 11:23 PM   #1
blown240
blown240's Avatar
Removing Ball Joints / Springs
I went out today to swap front springs on my 66 GMC and I couldnt get the lower ball joint to seperate from the spindle. I took off the kotter pin, the nut and the washer and used a pickle fork to get it off, but it never budged. I even soaked it in PB Blaster.
Is there a trick to getting these off?
blown240 is offline   Reply With Quote
Old 04-01-2011, 11:33 PM   #2
jj1965
jj1965's Avatar
Re: Removing Ball Joints / Springs
Sounds right to me, might check your pickle fork to be sure it is wide enough. Let it soak for a while and maybe a little heat it has worked for me in the past. Be sure to secure your spring!
jj1965 is offline   Reply With Quote
Old 04-01-2011, 11:36 PM   #3
chevylookin
I just did mine the other day. I replaced my ball joints so I heated up the A arm up with a torch and just pounded the ball joint out with a regular size hammer! One of the ball joints pretty much came apart into many pieces! I heard that it is not a good idea to torch the a-arm as it will increase the size of the ball joint hole but I think we are talkin tiny milli meters. If you intend on reusing the ball joints, I would line up two castle nuts on top of the ball joint threads with just a small amount poking over the top of the threads and start tapping away. Put a jack under the a arm and put about an inch of tension on it will you tap away. It will finally eventually give up!
chevylookin is offline   Reply With Quote
Old 04-01-2011, 11:51 PM   #4
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
You are supporting the lower arm with a jack I hope. I would leave the nut threaded on a bit in case something turned loose before you are ready .
If your taking the bottom joint loose a solid blow with a 2 lb hammer in the circled part of the pic will do it.
powerdriver 1958 is offline   Reply With Quote
Old 04-02-2011, 12:18 AM   #5
blown240
blown240's Avatar
Thanks guys. Ya I have the arm supported. I will try it again to see if I can get it out.
Old 04-03-2011, 02:35 AM   #6
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: Removing Ball Joints / Springs
Time to invest in a air hammer pickle fork and a air compressor
stsalvage is offline   Reply With Quote
Old 04-03-2011, 09:08 AM   #7
blown240
blown240's Avatar
Oh I have an air hammer, a pickle fork, and a compressor. I just didnt want to use them in case I was doing it wrong.
Do the steering arms have to be removed to get the ball joint off?
Old 04-03-2011, 12:22 PM   #8
chevylookin
Well, yeah the steering arms are bolted to the spindle. Time to take them off and degrease em and paint em all up nice in purrty anyways!
Old 04-03-2011, 12:24 PM   #9
powerdriver 1958
Kid's Mechanic
if your just swapping springs , NO
