Old 07-18-2007, 12:12 AM   #1
Jim_PA
u-joint straps, or u-joint u-bolts?
I'm thinking you know which one you need, depending on weather or not the yoke on the rear is threaded or not?
I'm swapping a 71 (or 72) rear into my 68, and the u-bolts from the 68 are too narrow. I've noticed the new rear has threaded holes through the yoke, and the holes are further apart than the old.
Jim_PA is offline   Reply With Quote
Old 07-18-2007, 12:23 AM   #2
Ackattack
Ackattack's Avatar
Re: u-joint straps, or u-joint u-bolts?
My 72 uses a strap and bolts.
I suggest going to the parts store to get new bolts, because the heads on them are really small. In the past I have used regular grade 8 bolts from the hardware store and the heads got chewed up cause they're big.
Ackattack is offline   Reply With Quote
Old 07-18-2007, 12:27 AM   #3
cell
Active Member
cell's Avatar
you probably need the straps. my 67 orignally had u-bolts, but they were rusted solid into the yoke. when I replaced the yoke, I think it was off of a later truck, because it had straps instead of u-bolts.
cell is offline   Reply With Quote
Old 07-18-2007, 12:35 AM   #4
Jim_PA
Thinking more about this.... How in the world would I get a u-bolt through a threaded hole???? What was I thinking... must be the Old Mil.
Good idea about the better bolts though!
Old 07-18-2007, 12:47 PM   #5
speedracer
Blank
speedracer's Avatar
they stopped using the u bolts after 1970 i believe. every 71+72 I've seen has straps but the yokes are interchangeable.
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 07-18-2007, 12:52 PM   #6
Jim_PA
Seems to me that the u-bolt would be stronger? -- There must be at least 2 different widths of straps also.
Old 07-18-2007, 04:23 PM   #7
Blazer1970
Blazer1970's Avatar
U-bolts are definitely stronger. No self-respecting off-roader would run those crappy straps.
Blazer1970 is offline   Reply With Quote
Old 07-18-2007, 05:12 PM   #8
70rs/ss
70rs/ss's Avatar
You could swap the yolk to keep running the u-bolts. There are some after market billet caps that work way better than the straps, about $25 for them and you'll never break em. Summit or Jegs
70rs/ss is offline   Reply With Quote
Old 07-18-2007, 06:28 PM   #9
Jim_PA
u-bolts vs billet caps... any opinions?
I got some straps today, but will either go billet, or swap yokes in the future when the day comes that I need a new seal.
Old 07-18-2007, 06:35 PM   #10
kelsfine69
18 Till I Die
kelsfine69's Avatar
Never seen billit...got a link?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 07-18-2007, 06:57 PM   #11
Jim_PA
http://www.jegs.com/webapp/wcs/store...10002_14518_-1
