01-26-2008, 01:30 AM | #1 |
GM Crate Motor turnkey 385 fastburn
Later this year I was planning on rebuilding or buying this motor. My question is with the turnkey it does comes with the single belt set up but I have not been able to determine if it includes the power steering and the AC compressor.
I've tried to contact Gmhorsepower.com but with no response. plus I was currious if anyone is using this motor and what they think. thanks
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) |
01-26-2008, 01:50 AM | #2 |
Re: GM Crate Motor turnkey 385 fastburn
I'm fairly confident the "tunrkey" comes with accessory drive package GMPP P/N 12497698; this is in the GMPP 2007 catalog.
Includes all accessory items: air conditioning compressor, alternator, water pump, power steering pump, plus all relevant pulleys, belts, brackets and fasteners. |
01-26-2008, 01:53 AM | #3 |
Damn Yankee
We carry them and they do come with the accessory drive package. Putting that exact motor in an '82 Vette out in the shop as we speak
01-26-2008, 01:55 AM | #4 |
Comes with Power Steering but has an A/C idler pulley in place of A/C compressor unless you option for it. Bracket is there belt is the same. A newer style I believe its a C4 compressor (don't quote me) bolts in place.
My Pop purchased it recently for his 68 Landcriuser w/330hp Vortec Crate engine, its not the 385 fast burn but it has the same drive kit, all GMPPP are good stuff plus a warranty you can't shake a stick at.
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap Last edited by Scott68-93-97; 01-26-2008 at 01:57 AM. |
01-26-2008, 02:03 AM | #5 |
Damn Yankee
It does come with the compressor AND the idler pulley; you can install either.
01-26-2008, 02:28 AM | #6 |
Thanks, I've been trying for the last two weeks to get that answer and I got it in less than an hour....gotta love this site.
01-26-2008, 06:27 AM | #7 |
Everything you see here is included
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug |
