Old 07-11-2006, 08:06 PM   #1
kombreeze
Spark # and gap
I've changed my truck to HEI. She's powered by a stock 68 327, ugraded edelbrock performer intake and carb 600cfm with dual exhaust and headers. Wanted to know what the parts numbers are for certain plugs to run....do I run the stocks with a larger spark or should I run a hotter plug. She ran good with the .35 gap but I know that's not the best way to run the plug....
kombreeze is offline   Reply With Quote
Old 07-11-2006, 08:44 PM   #2
jescates
jescates's Avatar
Re: Spark # and gap
I have pretty much the same setup, the exception is I have a small block 350. I used AC delco plug R45TS plug gapped to .045. Havent' ran into any problems. I would think the 327 should be the same, might be wrong though!
1970 C-10 LWB
1998 Jeep Wrangled TJ
2009 Honda VTX 1300
2013 Buick Enclave
jescates is offline   Reply With Quote
Old 07-11-2006, 09:00 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Spark # and gap
Yup, .035/points, .045/HEI. Your engine is still basically stock, so your stock AC Delco plugs are just fine.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-11-2006, 09:59 PM   #4
kombreeze
Re: Spark # and gap
I still have the fatter plug style....I've been told to use a lil hotter plug because the stock for points would be to cool. Do I just gap my plugs to .45 and run them like that......?
Old 07-11-2006, 10:33 PM   #5
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Spark # and gap
I believe you could run the r45 wich is the bigger 13/16 plug and gap it at .45
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
