Old 02-23-2009, 11:05 AM   #1
Storm Chaser
Storm Chaser's Avatar
700r4 with Edelbrock carb (corrector bracket)
Is anyone running a 700r4 with an Edelbrock carb? Are you using the TV corrector bracket?
I was looking at these corrector brackets on the Summit website...
TCI's bracket is $42.88
B&M's is $41.95
Hughes is $41.88
And the Summit house brand is $18.95
Now, all these brackets are pretty much the same, so one would be out of their mind not to get the Summit one, but let's face it- it's just a piece of metal. Anyone have one who could provide measurements to make one?
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 02-23-2009, 11:58 AM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: 700r4 with Edelbrock carb (corrector bracket)
Lokar has the best set up for this..
http://www.lokar.com/interior_pages/tc_kd.htm
tvblazer78 is offline   Reply With Quote
Old 02-23-2009, 01:32 PM   #3
Storm Chaser
The Lokar stuff is even more expensive than the stuff I listed. I want to make the part so my cash outlay is 0.
1988 R2500 Crew Cab
Future plans-
Old 02-24-2009, 11:00 AM   #4
Storm Chaser
The only measurement I need from someone running one of these brackets is the distance between the center of the bottom mounting hole and center of the 'relocated' TV stud. Anyone?
1988 R2500 Crew Cab
Future plans-
Old 02-24-2009, 03:12 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
There's a diagram of the GM specification on what TV cable geometry should be with respect to the throttle shaft floating around somewhere. Wish I had the link to it.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 02-24-2009, 08:54 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Here ya go homie!!
http://purplesagetradingpost.com/sum...o/700R4p7.html
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-24-2009, 09:20 PM   #7
C-10volvo
C-10volvo's Avatar
I would pay 18 dollars not to have that ugly job sitting next to my carb, but I guess it gets the job done.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 02-24-2009, 10:38 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
I built my own bracket out of metal plate and adjusted it to the proper distance for a good operation.
piecesparts is offline   Reply With Quote
Old 02-26-2009, 03:38 AM   #9
factory2wdblazer's
factory2wdblazer's's Avatar
there's a few diffrent bracket's that will work for you. edelbrock has on for about $30-$35 buck's it bolt's to the intake manifold hold's the throttle and the t.v cable. specturm has one for about $15-$20 buck's bolt's to the back of the carb also hold's throttle and t.v cable. i just did a 700r4 swap in to my 73 blazer. the best thing to do is to go to your local transmission shop and buy a longer t.v cable.............i did yesterday if cost me $40 buck's installed............the t.v cable must be hooked up correctly if not you can and will fry your transmssion i hear..........also if you have a lock up converter you want it hooked up to work..............
factory2wdblazer's is offline   Reply With Quote
Old 02-26-2009, 10:26 AM   #10
gchemist
gchemist's Avatar
I bought mine at www.jcwhitney.com. Cheapest price I found anywhere.
Old 02-26-2009, 12:33 PM   #11
Storm Chaser
Yea, gchemist, that looks like the piece I'm talking about- it bolts to the trottle arm of the carb and relocates the TV stud rearward. I just need to know the distance between the center of the lower mounting hole to the center of the TV stud.
What are you using for a throttle cable mount? Factory?
1988 R2500 Crew Cab
Future plans-
Old 02-26-2009, 06:08 PM   #12
gchemist
gchemist's Avatar
I'm using Edelbrocks bracket. My measurements won't work if you are using a stock bracket.
Old 03-18-2009, 09:29 PM   #13
tekno62
how did you search for the bracket at www.jcwhitney.com?
tekno62 is offline   Reply With Quote
Old 09-15-2012, 01:15 PM   #14
1955 mancave
1955 mancave's Avatar
that is what i will be doing, i'm not taking any chances on doing it wrong and burning up my new trans.
1955 mancave is offline   Reply With Quote
Old 09-16-2012, 08:57 AM   #15
gchemist
gchemist's Avatar
I used the stock part number from Edelbrock. Use stock numbers on any part from a major manufacturer. JCWhitney may not advertise it in their catalogue. They do carry an extensive list of parts not listed.
