Old 08-02-2005, 12:55 PM   #1
nosto
Flamin' Bass
nosto's Avatar
Angry #@%$^& fuel float - again!
OK, I'm ranting, but this is the THIRD fuel float in less than 3 years that has decided it wanted to sit on the bottom of my poly Blazer tank instead of floating. Now I get to find a way to drain ~15 gals of gas, drop the tank and pull the float.
Does anyone have an alternative to the soldered brass(?) float, like maybe a plastic one, or would a cork do the job?
Rant off....
Thanks,
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 08-02-2005, 06:00 PM   #2
FUNMUDDER
FUNMUDDER's Avatar
Try patching JB-Weld on it. We used it on a John Deere float and it worked great. Gas resistant, good stuff!!!!
FUNMUDDER is offline   Reply With Quote
Old 08-02-2005, 06:07 PM   #3
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
when I was having my tank coated, the guy offered to dip my float as well. he said it was an easy fix. try your local rad shop that does tanks. as for draining it, I had to do it the (yuck!) old fashioned way & siphon it out. Just have a few gas cans on hand...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 08-02-2005, 07:06 PM   #4
walker
walker's Avatar
Just run the gas out of it. In fact, if you know what kind of mileage you get just go fill 'er up and calculate how many miles you can drive on a full tank and go drive that many. Then just drop the empty tank.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 08-02-2005, 07:20 PM   #5
Jwill41
Jwill41's Avatar
Im with Walker on this one. Just go cruisin.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-02-2005, 09:49 PM   #6
ratfreak888
get a new float and drown that sucker with seal-all available at any hardware store
ratfreak888 is offline   Reply With Quote
Old 08-03-2005, 10:18 PM   #7
Tim Christian
Tim Christian's Avatar
I have had 3 to come back to me in the last couple of weeks!!!
Tim Christian is offline   Reply With Quote
