Old 10-11-2015, 06:04 PM   #1
Captmatt
Headlight help
The headlights on my 64 C10 have stopped working. The BRIGHT indicator light is on and does not turn off after depressing the floor switch. It's most likely something simple but electrical is not my strong point. Thought I'd start with you guys before I waste a lot of time. Thanks in advance.
Captmatt is offline   Reply With Quote
Old 10-11-2015, 08:04 PM   #2
T and S
T and S's Avatar
Re: Headlight help
Do you have a wiring diagram and a multi-meter ? These are essential tools to trouble shoot electrical problems.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 10-11-2015, 08:31 PM   #3
PGSigns
PGSigns's Avatar
Re: Headlight help
You need a test light at least to get started looking for the problem. These trucks have a habit of burning up the wiring at the dimmer switch. Easy to take a quick look. Have you looked at the fuse?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-12-2015, 07:27 PM   #4
Captmatt
Re: Headlight help
I'm going to dive into it tomorrow . I was just hoping that because the bright light indicator is now on all the time (with the light switch on) that someone would recognize this as a problem they once had and could point me in the right direction. Thank you for the response .
