PB Touring Dropmember or No Limit Wide Ride
New member here about to start on my 66 GMC SWB, I am looking at installing the PB Touring coilover dropmember or the No Limit Wide Ride. The truck will be autocrossed some but driven a lot on the street also. I have built a couple pro-touring first gen Camaro's and want the truck to handle really well.
Which one of these is close to truly being a bolt in crossmember? Will I have to cut out my inner fenders for both? Can either one use a stock steering column? The truck will have a Ridetech Parallel 4 link on the rear if that makes any difference. Thanks for any help or suggestions. |
Re: PB Touring Dropmember or No Limit Wide Ride
wide ride (which is the route I'm going), is bolt in, cannot use the stock column since it has rack and pinion, no cutting of inner fenders unless you just lay the frame (which is true for all trucks and not confined to the wide ride setup
![]() Join Date: May 2007
you can do a search in the suspension forum on this
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#4 | |
Thanks, that's what I thought. I have searched all over the forum and it's hard to find a ton of info on the No Limit setup. I have looked at your build on pro-touring and like what your doing with the truck. |
thanks, yeah I'm emailing every so often with Rob from no limit with my own questions. trying to scrape the money together right now as No Limit is moving their shop to Tn, and will be only 1.5 hr from my house so I'm super stoked about it.
![]() Join Date: Aug 2013
you should sale those unwanted front suspension parts also, if ur never gonna use em again, some folks are looking for those items i.e. oem spindles and such!!!
I didn't know he was moving his shop, most of the people running the wide ride have a 67-72 and the inner fenders are a lot different. I'm hoping someone in here has a 60-66 that has already installed one. Just haven't found it yet. Are you going to order it directly from Rob?
