View Poll Results: What Distributor! | |||
Mallory | 4 | 12.12% | |
MSD | 16 | 48.48% | |
ACCEL | 0 | 0% | |
OTHER please specify | 13 | 39.39% | |
Voters: 33. You may not vote on this poll |
01-10-2009, 05:54 PM | #1 |
HERE.......Somewhere
Distributor?
I need to get one for a good price but dont know what brand I should get
The most I may put into one will be 200 to 250?
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
01-10-2009, 06:07 PM | #2 |
Burnouts are therapeutic
Re: Distributor?
msd has an hei for about $160 in jegs complete coil and everything can't beat that, its called streetfire or something
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
01-10-2009, 06:08 PM | #3 |
its all about the +6 inches
Re: Distributor?
skip white, 50 bucks
01-10-2009, 06:12 PM | #4 |
Gone to greener pastures
Re: Distributor?
Don't quite know how to answer your poll, but I'll give you some personal experiences:
I have a 35+ year old Mallory that we used to run in a race car. Then I ran it in my V-8 Vega until I got rid of the car. Now we use it as a "test bed." Anytime we suspect we have a distributor problem on something, car/truck/boat, we jerk the distributor & drop in that Mallory. It never fails us. I had an ACCEL in one of my boats, loved it to death. When I bought my '69, it had an ACCEL in it, biggest POS that ever came down the pike. I replaced that ACCEL with a complete MSD system; spark box, coil, distributor & plug wires. I can't say enough good things about it. I hit the starter & the truck fires. Just my .02.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 01-10-2009 at 07:16 PM. |
01-10-2009, 06:28 PM | #5 |
Hollister Road Co.
Re: Distributor?
I just got the skip white $50 one and its evry bit as good as the higher priced brands.
01-10-2009, 06:42 PM | #6 |
The Early Chevy Van Man
Re: Distributor?
where might one buy this 'skip white' distributor? I think I want one
64 Chevy Van 65 GMC Handi-Van 99 2500 silverado 4x4 ext cab |
01-10-2009, 07:11 PM | #7 |
Re: Distributor?
Yep, got one of the Skip White dist from Ebay for our 383. Good unit but -- Vacuum advance screw adjuster did not work, replaced with a spare vac adv I had. The unit I got only has 16 degrees mechanical advance, and 14 deg initial advance is all I can run and have it start without kicking back, so I am limited to 30 total mechanical advance. I'll have to see if I can get it to do a little more when it warms up. I also changed to lighter springs in the advance, but that is a tuning thing, nothing bad about that.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 01-10-2009 at 07:12 PM. |
01-10-2009, 07:36 PM | #8 |
Re: Distributor?
uhh where do you get the skip white brand???? also which would be good a regular one or an electronic one????
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! Last edited by 70' GMC; 01-10-2009 at 07:39 PM. |
01-10-2009, 07:41 PM | #9 |
Moderator
Re: Distributor?
Summit brand HEI unit, really no different than the accel from what I can tell, and you get the adjustable vacuum advance can, it runs around $100...
But if you can get a new one for $50 then there's your answer. Spend the rest on something more fun!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
01-10-2009, 07:44 PM | #10 |
Roadtrip!
Re: Distributor?
I think for what you want i would go electronic. There are alot of aftermarket ones out there for less than $100
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-10-2009, 08:08 PM | #11 |
Re: Distributor?
I took the stock HEI unit out of my 83 454 and it makes my 71 402 run like a dream. Only had to change the lead wire to a higher gauge without the resistor. Of course you need HEI wires and re-gap your plugs to .045.You can probably get one from a junk yard really cheap.
Dan
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 Last edited by hilandr452; 01-10-2009 at 08:10 PM. |
01-10-2009, 08:16 PM | #12 |
Re: Distributor?
I can personally reccomend the MSD pro-billet.
Mechanical advance. easy to change, pigtails directly to an MSD 6 or 7 series ignition (gives you digital ignition) which makes starting the truck WAY FRICKIN EASY!!! MSD is good at giving you extra parts for installation and timing choice, as well as complete directions. Their tech support is a wee bit stupid in the face though. http://limerock.racingjunk.com/post/...stributor.html
RN U OVR Last edited by Senator350; 01-10-2009 at 08:18 PM. |
01-10-2009, 08:19 PM | #13 | |
Re: Distributor?
1968 GMC Rebuilding Stage 2001 Camaro SS SOLD |
01-10-2009, 09:03 PM | #14 |
Re: Distributor?
MSD Streetfire here.. no complaints
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 http://i195.photobucket.com/albums/z...en58/001-2.jpg |
01-10-2009, 08:17 PM | #15 |
Insert Title Here
Re: Distributor?
I have a Mallory in mine....no probs so far, been over a year sense I swapped it
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
01-10-2009, 09:27 PM | #16 |
Re: Distributor?
So,who wants to know where to buy a Skip White unit?cost ya $50 to find out. (I just don`t know.Ebay,I think?)
The factory HEI "is" a performance distributor.You`d need alot of motor before needing anything more.You can put lighter springs and heavier weights for faster advance.But,not necessary until engine dynamics are changed.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-10-2009 at 09:29 PM. |
01-10-2009, 10:03 PM | #17 |
Re: Distributor?
so, speaking of engine dynamics...
what did most of our small blocks come with as far as head specs (intake, exhaust, and cc). these are the dynamics that dictate degree and speed of advance
RN U OVR |
01-10-2009, 10:47 PM | #18 |
Msgt USAF Ret
Re: Distributor?
Vettevet to the rescue.
http://stores.ebay.com/whiteperformance1
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-10-2009, 11:42 PM | #19 |
Re: Distributor?
MSD pro billet all the way!!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-11-2009, 08:48 PM | #20 |
Re: Distributor?
Is that points on that or something else?
01-11-2009, 09:01 PM | #21 |
Re: Distributor?
Electronic
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
01-10-2009, 11:56 PM | #22 |
STOLEN
Re: Distributor?
Still rolling with points. Someday I'll switch over...maybe.
In Search Of |
01-11-2009, 02:04 AM | #23 |
Re: Distributor?
guy I got my 6AL from was switching BACK to points???
also, got my MSD probillet for 200, from someone who couldn't use the gift in his camaro. saved a couple bucks
RN U OVR Last edited by Senator350; 01-11-2009 at 02:07 AM. |
01-11-2009, 02:57 AM | #24 |
Re: Distributor?
That don't sound real bright to me.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 01-11-2009 at 05:19 AM. |
01-11-2009, 01:59 AM | #25 |
Re: Distributor?
Got one on sale at Jegs for like.. $80.00 or something.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
