Old 05-31-2010, 05:19 PM   #1
truckdude239
truckdude239's Avatar
crazy issuse
was out working ont eh 71 got my water leak fixed but i let it idle for about 10 mins while i was removing the rear bumper then it just shut down like someone had cut the key off. (yes it also dieseled) and wouldn;t start back ( it didn;t want to turn over like the timing was off) let it sit for about 5 mins it started right up ran for 5 mins then same thing? does that sound like a bad coil? i have a skip white hei in the truck
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-01-2010, 05:29 AM   #2
silverstreak
Re: crazy issuse
Shutting off and not wanting to restart until it has cooled down, is similar to what I've experienced when a coil or ignition module is going bad. However I've never experienced a slow cranking situation during that time, it would just crank normally and not fire.
I'd get one of those inline spark testers then let it run until it dies again, then check to see if you have spark when you go to restart it.
silverstreak is offline   Reply With Quote
Old 06-01-2010, 09:22 AM   #3
Shyguy
Junior Member
Shyguy's Avatar
Re: crazy issuse
The only time I have problems with the '71 not turning over or turning over slowly is because of heat soak of the starter caused by the headers.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
