Old 07-06-2016, 01:37 PM   #1
FB85C10
Transmission ?
can this be repaired, its a TH350C transmission:
FB85C10 is offline   Reply With Quote
Old 07-06-2016, 01:46 PM   #2
GRADYS Performance
GRADYS Performance's Avatar
Re: Transmission ?
No, Because the dowel pin hole has been broken off the case, the engine to transmission alignment cannot be maintained even if welded back together. The case should be replaced.
GRADYS Performance is offline   Reply With Quote
Old 07-06-2016, 09:18 PM   #3
Desert1957
Desert1957's Avatar
Re: Transmission ?
350 Turbos should still not be that hard to find. Have some one swap the guts over to a new case. Or do it yourself, it is not that difficult.
Desert
Desert1957 is offline   Reply With Quote
Old 07-08-2016, 04:54 AM   #4
andrewmp6
Re: Transmission ?
There is metal stitching but would cost more then a new trans would.I'd look for a new trans like you have or maybe upgrade to a 700r4.
andrewmp6 is offline   Reply With Quote
Old 07-08-2016, 06:00 AM   #5
minitrail
Re: Transmission ?
Just out of curiosity how did that happen? Looks like a recent (clean) break.
I agree look for a replacement.
minitrail is offline   Reply With Quote
Old 07-08-2016, 09:28 AM   #6
hatzie
Moderator
hatzie's Avatar
Re: Transmission ?
It's broken around the dowel pin. That's what aligns the center of the mainshaft. It can never be repaired such that the mainshaft alignment will be correct.
I assume the TH350 is otherwise almost new...
If you can find a worn out TH350C core you could swap the internals over. That's only worth it if the core is free, or darn close to free, and the one you have only has a few hundred miles on it.
I think I'd go the upgrade route with a decent TH700R4.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-08-2016, 11:51 AM   #7
SkinnyG
SkinnyG's Avatar
Re: Transmission ?
It ~could~ be repaired, but you'd want to jig it up to make sure that the crank centerline and input centerline are perfect. This may require disassembling the case anyway, or just gamble and try your best to get it lined up in the truck.
I say see if a good welder near you can do it. TIG is best, but a spool gun could work.
Put it this way:
Right now it's messed.
If you are successful in welding it, at worst it will be less messed.
If you can't fix it, well - it was broken anyway.
You really don't have anything to lose by trying.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
