01-16-2009, 02:41 PM | #1 |
Need help installing transmission
I have a 1972 K10 350/205 my automatic transmission will not go more then 30mph and leaks oil like crazy is there a guide on what nuts and bolts to remove to swap out an automatic 4X4 transmission? do I need to remove the adapter and the t/c
01-16-2009, 02:59 PM | #2 |
the pollock
Re: Need help installing transmission
rear drive shaft
front shaft transfer case tranny prettu much in that order.. it a PITA but cheaper to do it yourself then paying a shop
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
01-16-2009, 07:29 PM | #3 |
Modern day Fred Sanford
When removing the case take out the four bolts that are holding the adapter and case to the trans.It will be a lot easier than leaving the adapter on the trans and pulling the case.
01-16-2009, 09:50 PM | #4 |
I took out the T/case, the adapter and remove all the bolts that attach the tranny to the engine but im having a problem sliding it out. it comes out about 3/4 of an inch then it wont budge, do I need to remove the stater or do I just need to hammer this thing out?
01-17-2009, 12:00 AM | #5 |
huh ???
Unbolt the starter, you'll also need to unbolt the torque converter from the fly wheel, otherwise you'll mess up the trans pump...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
01-20-2009, 10:57 AM | #6 |
Thanks guys for your help, It took me 3 days but it runs awesome no oilleaks I ended up removing the shafts, tranfercase, adapter, frame crossmember, and transmission in that order.
01-20-2009, 01:23 PM | #7 |
the pollock
sweet bet u diddnt take pictures .....dang
every time i dop a trannuy i end up with so much oily filth on me.. then my wife runs away cause all i want is a huuuugggg... ha ha ha.. good job dude.. u just saved yourself a grand
