Old 02-21-2016, 10:13 PM   #1
clockdoc
clockdoc's Avatar
Oil Pressure Sender for Aftermarket Gauge
I've replaced the idiot lights on my 1978 C10 (305 V8) with water temp., oil press., Voltmeter and tach, all 2 inch gauges. All are working except for the oil pressure, which I haven't found a place, that I can get to, to put the sender. Is there another port, other than the oil pres. switch port behind the distributor, that I can use? If not, any tips about getting to the oil press switch sender to replace it with the new one would be appreciated.
CLOCKDOC
clockdoc is offline   Reply With Quote
Old 02-22-2016, 12:37 AM   #2
barry1982
Re: Oil Pressure Sender for Aftermarket Gauge
I am not aware of any other place on the small block to mount the oil pressure sending unit. I know they are in a bad spot, I bought a cheap combination wrench, heated and bent to make it easier to remove the original. If I remember right, your sending unit is large and round. You may be able to
slip a small strap wrench on it higher up.
barry1982 is offline   Reply With Quote
Old 02-22-2016, 12:54 AM   #3
Front Range
Front Range's Avatar
The TBI blocks have an additional port above the oil filter, Not sure about the earlier carbed blocks but you might take a look and see if you have a plug there.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 02-22-2016, 05:21 AM   #4
chengny
chengny's Avatar
Just three different views showing the location of the oil port just above the oil filter mounting flange:
It's location within the lube oil system. Note that in a schematic sense, it is in the same place as the port behind the distributor:
That port is drilled and tapped for 1/4" - 18 NPT. The one behind the distributor is 1/8" - 27 NPT.
chengny is offline   Reply With Quote
Old 02-22-2016, 09:15 AM   #5
clockdoc
clockdoc's Avatar
Good tips from all Thanks for the info. The pictures are especially helpful. I'll look for that port over the filter. Thanks again.
CLOCKDOC
Old 03-03-2016, 06:08 PM   #6
clockdoc
clockdoc's Avatar
Thanks for the excellent response. I finally got back to this yesterday and, once I coaxed the plug out, it was relatively easy to install the sender. Not an easy place to work but, I have to believe, easier than the other site. Thanks again!
Clockdoc
