Old 03-02-2011, 07:22 PM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
3/4 Ton Springs, and new ball joints
I getting new coils all the way around for my '68 c10, I ordered 3/4 ton springs, I'm planning on replacing the ball joints while I got everything apart. Should I get 3/4 ton ball joints? Or will these even fit? Thanks Y'all!
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 03-02-2011, 10:12 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: 3/4 Ton Springs, and new ball joints
do you still have the stock 68 front drums? I believe your ball joints should match your spindles
Also, is your truck a C20 or C10....why did ya go with 3/4 ton springs??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-02-2011, 10:18 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Unless you are swapping to 3/4-ton spindles,... you will need 1/2-ton balljoints.
(also the 3/4-ton lower a-arms are different than your 1/2-ton lower a-arms)
Keith
Convert to disc brakes.
Old 03-02-2011, 10:32 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
whew...I was channeling my inner Keith, and wa-la....you showed up Thanks for the response Keith....
Geoff with a G
Old 03-02-2011, 10:43 PM   #5
1968CHEVYC10
ok thanks guys, yeah every thing is still original c10 parts. I just thought it might be a good Idea to use heavier duty ball joints if they'd fit. Oh well thanks again
Old 03-03-2011, 09:49 AM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
so why did ya go with the 3/4 ton springs....not that it's wrong, I'm just curious??....
Geoff with a G
Old 03-03-2011, 05:42 PM   #7
dan76
Unless you're staying strictly stock...I'd recommend going to front disc brakes at this time as you'll have everything apart.
dan76 is offline   Reply With Quote
