09-24-2012, 07:19 PM | #1 |
1977-79 malibu 350 into 1971 chev truck
Will this motor fit in my truck? Just want to make sure before I buy it as I heard a oldsmobile car motor would not fit.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
09-24-2012, 07:26 PM | #2 |
Re: 1977-79 malibu 350 into 1971 chev truck
A Malibu is a Chevrolet built car, not Oldsmobile. So, unless someone dropped a OLDS 350 Rocket, yes the engine will drop in on the factory mounts in your truck. That is if it has the V-8 mounts.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
09-24-2012, 07:33 PM | #3 |
Thanks Joe, and yes I have a 350 in there now with a broken ring on one cylider so hopefully its a pretyy simple drop in without any issues.
09-24-2012, 07:51 PM | #4 |
I used to work with a guy that had a chevy truck with a 350 olds in it and hooked to a chevy 350 turbo, if I remeber right it only had 2 bellhousing bolts in place..lol
But like was said that motor should drop right in same,same. Posted via Mobile Device |
09-24-2012, 07:58 PM | #5 |
Motor mounts aren't the same for OLDS and Chevrolet/GMC. Same goes for the bell housing bolt pattern. So, like I said before, if it is an actual Chevrolet 350 it will be a direct bolt in. Good luck with your motor swap.
09-24-2012, 08:03 PM | #6 |
Ah yeah, kinda what i was saying by saying it was only useing 2 bellhousing bolts... Fit but not right.
