I am not a wrench, in fact, I had to use spell check to even spell wrench. I have found a SBC 350, it is complete with 77K original miles on it. Out of a 1980 blazer. I can buy it for $300. My question is...is this a fair price, too high or a steal? I can not hear it run as it is on a stand for sale. To me it looks like a motor, like I said, I can barely put gas in the crazy things to make 'em go. The owners says it was running strong and no smoke when he took it out. At some point I want to swap my L6 for a SBC.
Any ideas? Thanks!!!
Douglas King Independence, MO |
go cyclones
You will want to check if it has a four bolt main. You can get the numbers of the block to tell if it is or not. As far as 1980 350 I really don't know what heads and internal stuff they used that year. I would look around you can often find 350s cheaper.
Car Knocker
with it being on a stand you are ALMOST at his mercy. You could run a compression test and make sure it is all good. You could also hook an oil gauge to it and spin the oil pump with a drill and check oil pressure. Pull a valve cover and look and see how well and often the oil was changed,ie no sluge. Or you could just take him for his word and hope that it doesn't have a Sherwin Williams rebuild on it. Will he back up his claim will a warranty if it is indeed bad,smokes? Also look on the back of the block behind the intake on the flange where the tranny would bolt up, drivers side. If it says "hencho de mexico" I would pass, as these blocks have a low nickel content and in my experiece CRACK if they even get a little hot. Good Luck
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
Drive it like U stole it
300.00 and you cant hear it run . I think thats a little much . I would give half that or the most 200.00
71 custom 10 swb 72 nova ss 72 nova custom 87 s10 96 burb 94 camry 53 5 window 3100 |
Thanks guys! It would seem that I have much to learn about motors, etc.
I will keep looking.
John Sacramento Area 1969 C10 Fleetside |
or this one my ahve more info... sorry
http://www.nastyz28.com/sbchevy/sblock.html
Thanks John. Great stuff. I am considering taking a class at our local Vocational-Technical school in auto body and another in auto mechanics. In both classes, you buy the material and they provider the tools, shop and instruction on how to do the work. Sounds like a good deal to me. Now if I can just find an old tired 350.
![]() Thanks again!
