03-01-2020, 05:28 PM | #1 |
How To Install Brake/eBrake Pedal Pads
Just received a set of deluxe pedal rubber pads. Any trick to installing them without tearing them ?
71 C-20 07 Magnum RT AWD |
03-01-2020, 09:01 PM | #2 |
Re: How To Install Brake/eBrake Pedal Pads
Put them in the sun or warm them up with a hair dryer first to make them more pliable. You can also spray the backing with silicone to help it slip over.
03-02-2020, 04:37 PM | #3 |
Old member
Heat and soap!
03-09-2020, 10:43 AM | #4 |
Bet your dad he can't get them on. Works every time!
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
