Old 07-20-2011, 04:37 PM   #1
veinbar
veinbar's Avatar
TH400 to 700r4 Conversion
I have a TH400 currently that needs to be rebuilt. With the suggestion of a few members I am now considering a 700r4 conversion. I drive a '79 SWB 1/2 2-wheel drive Bonanza. I know that the 700r4 will bolt up to the motor and cross member w/ no issues. The questions I do have:
  1. My '400 has a 2-piece drive shaft. I will need a 1-piece for the 700r4. Does anyone know the exact length of a driveshaft on a '73-'80 truck w/ a 700r4?
  2. Will the linkage have to be modified?
  3. Will the direct line from the tail of the 700 to the 12 bolt be a safe/operational angle?
  4. I know that the 700r4 requires additional cooling, but what else can I expect to change or modify with this conversion?
  5. Do driveshafts really need to be balanced anymore? some people say yes, some say no.
  6. Some 700r4 cores are better than others. Which years are the best cores to overhaul?
Other questions will pop up along the way, but this is a good start. Thank you in advance for chiming in with advice and information.
veinbar is offline   Reply With Quote
Old 07-20-2011, 05:33 PM   #2
Jonboy
Slots go on anything!
Re: TH400 to 700r4 Conversion
1. Not sure, but a 1 piece driveshaft from a shortbed with a long tailshaft TH350 works perfectly.
2. No. It may need to be adjusted, but it will work. You may want to find a quadrant out of a later model 700R4 equipped truck, if it matters to you.
3. Yes.
4. Not really. Heat is the enemy of any Automatic transmission, just not the 700R4. An auxillary cooler is never a bad idea (if it is installed right).
5. It can't hurt, especially if you are having one cut.
6. The really early ones had lousy pumps. Seems like 87-88 had an auxillary valve body added also.
Another note- I would look into some type of TCC engagement. Bowtie Overdrives sells a pretty nice kit for around $60, IIRC. It will include a new brake switch, too.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-20-2011, 05:51 PM   #3
VWBeamer
Here's a curve ball, get a 4L80E. It's basically a 400 with over drive. Super strong. And I know that the electronic part sounds complicated and expensive, but stand alone controlers are 500 bucks, but consider no messing with a TV cable, special throttle hook ups and no worry about how you are going to lock the converter, it's a good deal.
http://www.optishift.com/?gclid=CMWB...FcV_5QodY0J2xg
Plus the 4l80E is TONS stronger. ...and doesn't have the huge drop off in RPm between 1st and second gear.
I know it doesn't answer your question, but you can get a transmission that is twice as strong for just a little more effort and money.
VWBeamer is offline   Reply With Quote
Old 07-20-2011, 06:12 PM   #4
softballnrd27
Always a work in progress
softballnrd27's Avatar
The 4l80e is a good option but possibly overkill if you just plan to have a mild SBC. A 4l60e is the electronic version of the 700r4 so there isn't much of an upgrade from a 700 other than the electronic part, no TV cable.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 07-20-2011, 07:56 PM   #5
chevy-fun
chevy-fun's Avatar
88-93 700r4 are the betters one to rebuild
chevy-fun is offline   Reply With Quote
Old 07-21-2011, 10:01 AM   #6
veinbar
veinbar's Avatar
Thank you for the rapid responses. I think 700r4 will be more than enough to handle my near stock sbc. Perhaps a few internal upgrades for added strength and reliability. What would i have to do to make a 4L60E work with my truck? It would be nice to eliminate the tv cable.
Old 07-21-2011, 03:05 PM   #7
VWBeamer
The same controller made by optishift will work with either transmission.
To get an idea what is involved, here is the manual.
http://www.optishift.com/downloads/GMmanual.pdf
Old 07-21-2011, 03:13 PM   #8
Jonboy
You will also have to swap th a 90-91 Electrinic cluster or use somethng like a cable-x box to make the speedometer work. That is the biggest downfall of using the 4L60E/4L80E.
Old 07-25-2011, 10:31 AM   #9
veinbar
veinbar's Avatar
So perhaps it would be cheapest to run with a 700r4? I'm assuming the electronic aspect would be a bit more pricey.
Just a side question... You have a 350 TBI, 700r4 and a drop. You're probably getting some pretty decent mileage right. Do you know your hwy vs city mpg average? What rear gear are you running?
Old 07-25-2011, 07:45 PM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
My builder can probably get you in a nice 700R4 starting at $750+. Price goes up as parts are upgraded or added.
I run a 85 Camaro 700R4. The tailshaft is from a truck. Upgraded like crazy! You should go for a ride with me.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-26-2011, 12:35 AM   #11
Jonboy
It's rinning a 3.73, with a 255/70 rear tire. I am still working an a few teething problems from the swap, so it is hard to tell what kind of mileage I am actually getting. I have only run a tank of old gas through so far, so it's not really fair to try to average it just yet.
Old 07-26-2011, 04:50 AM   #12
INSIDIOUS '86
INSIDIOUS '86's Avatar
30 spline are the ones to get not specificly a certain year but 30 spline input shaft was done early-late 84 i believe?
http://www.transmissioncenter.net/ call these guys the know thier stuff and will stay on the phone with you for hours to answer any Q you have
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-26-2011, 01:53 PM   #13
veinbar
veinbar's Avatar
I'd love to. I could use some input from a local classic truck guy.
Old 07-26-2011, 02:19 PM   #14
Pop's C-10
Pop's C-10's Avatar
i think tha 30 spines came in about 88...
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-26-2011, 07:19 PM   #15
gchemist
gchemist's Avatar
GM used 27 input splines from 82-84. GM went to 30 in 85, hence my 85 Camaro 700R4. Strout motor Camaros and Vettes were stripping the input in spline. Later, aftermarket suppliers used hardened parts to make them stronger.
Old 07-26-2011, 07:21 PM   #16
gchemist
gchemist's Avatar
Oh yea, we'll go a nice ride!!
http://www.youtube.com/user/Silverad...14/SxscAUgYLeI
Old 07-26-2011, 08:54 PM   #17
54Caddy
GM Addicted
54Caddy's Avatar
I recently done this swap. All in all costed me about 1200. have a fully rebuilt trans with stage 1 shift kit and corvette servo. running a non lock up converter so no need to wire up trans. ordered a tail shaft housing cover that will make the 700r4 fir on the th400 crossmember with drilling or elongating of mounting holes. bought a driveline out of a truck with a th350 installed new ujoints and balanced it fit perfect. ordered lokar tv cable and throttle cable with bracket for edelbrock intake/carb set up. If youd like part numbers let me know.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 07-26-2011, 09:39 PM   #18
bradford
I would like the part numbers please.
bradford is offline   Reply With Quote
Old 07-26-2011, 10:17 PM   #19
gchemist
gchemist's Avatar
400th to 700R4 swap info: http://transmissioncenter.net/700R4_Swap_Info.htm
700R4 tip sheet: http://www.transmissioncenter.net/700r4.htm
Old 07-26-2011, 11:37 PM   #20
INSIDIOUS '86
those corvette servos are only like 15% more holdin power over stock with still isnt much for high torque, but a sonnax servo and some new boost valves and a lockup kit with shift kit makes a durable trans, and dont forget that beast shell! most shops put in new clutches and a shift kit with some stiffer accumulator springs and say its good. they still burn and break
Old 07-27-2011, 09:50 AM   #21
veinbar
veinbar's Avatar
I would love all of those part numbers. I ran into many issues when converting my '76 g10 to a 700r4. Needless to say the transmission lasted about 12k miles before it needed a rebuild.
Old 07-27-2011, 09:54 AM   #22
veinbar
veinbar's Avatar
Thank you... These are very helpful. I'll probably never have a reason to build a 700 as stout as yours, but I will need a solid 700.
Old 08-01-2011, 09:22 AM   #23
veinbar
veinbar's Avatar
Progress... Yesterday I pulled a 700r4 out of my '76 SportVan that will be going into my '79 Bonanza. It already has all of the internal upgrades I would want or need, just needs a rebuild.
Old 08-01-2011, 11:04 AM   #24
D.FENS
Not trying to get this thread off the track, but will a 700R4 last behind a 454 in a dually? Local trans builders give conflicting answers.
D.FENS is offline   Reply With Quote
Old 08-01-2011, 11:11 AM   #25
veinbar
veinbar's Avatar
I would suggest the 4L80E which is basically a TH400 transmission with overdrive. I'm sure a 700r4 can be built to handle just about anything, but it would need just about every internal heavy duty upgrade that is offered. You might want to compare the prices of both and make your decision.
