10-26-2017, 10:39 PM | #1 |
Fan clutch question
Can I clean my fan clutch in a parts washer without damaging it?
Posted via Mobile Device |
10-27-2017, 01:29 AM | #2 |
Re: Fan clutch question
I think I would keep the solvent off the seal where the shaft comes into the clutch itself. Otherwise it is a sealed unit. I usually clean them by spraying some brake clean on the front spring. The bi-metallic spring is what engages the clutch, when that is dirty it doesn't work properly
10-27-2017, 09:07 AM | #3 |
10-27-2017, 09:22 AM | #4 |
And it should be a lot of resistance. If you spin it, it should not make a full rotation.
