455 Buick in 63-66 C10 will it fit?
Yes I know, it’s a traitorous thought, but I have a perfect running ‘70 455 100% complete and ready to go with no home. Anyone ever done this swap? The exhaust manifold and oil filter clearance look mighty iffy. Thoughts?
Steve weim55 Colorado |
Re: 455 Buick in 63-66 C10 will it fit?
I put a 455 Olds in a 68 Nova. Most BOP car chassis are basically the same as a truck except the steering box is inside the frame rails. So with that part being out of the way the swap is a bit easier there. Don't lift the engine too high as passenger car headers are not as tall as truck headers by 1 inch roughly.
Other then that the Buick is my favorite big block. Great power, and mpg. Maybe one day I will getnto build one. Besure to run zddp or oil with zinc. Buicks 455's as of my last search can not get a roller cam. So I would hate to see you ruin the headers. |
Who Changed This?
![]() Join Date: Jan 2013
Go here and look around. This particular guy put a Buick Nailhead in his truck. Look for his posts, there will likely be lots of talk from others, as well.
http://www.v8buick.com/index.php?mem...-codman.10523/
It's Better With Nitro
Yes, it will.
