Old 05-13-2011, 10:17 PM   #1
skysoldier173rd
skysoldier173rd's Avatar
Starter Grinds
my starter makes a terrible noise about half the time when starting the engine. Appears not engaging properly sometimes. I took it off when i did the engine transplant into the old truck. The motor/trans is a 350/700r4 out of a late 80s gmc now in a 60 GMC. It worked fine when i removed it and I don't recall any shims. Ever since reinstalling it , i've had this problem. I'm wondering if it needs some shims and where. As it is, something will be stripped soon if I don't address the problem, either the ring gear or the starter. Any suggestions?
skysoldier173rd is offline   Reply With Quote
Old 05-13-2011, 10:23 PM   #2
notrailerqueens
notrailerqueens's Avatar
Re: Starter Grinds
chunk some shims at it and see if that fixes the problem
Lindsey Rae
85' chevy long box, built by a girl!
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=429956
notrailerqueens is offline   Reply With Quote
Old 05-13-2011, 10:48 PM   #3
TopFuel1966
TopFuel1966's Avatar
Re: Starter Grinds
Straighten out the end of a paperclip and use it to check the clearance between the drive gear and the ring gear. Adjust with shims accordingly.
TopFuel1966 is offline   Reply With Quote
Old 05-13-2011, 10:51 PM   #4
Rich 5150 69
Rich 5150 69's Avatar
Re: Starter Grinds
Ditto with topfuel, put shims on outside mount on starter to kick it in towards the flexplate ring.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-14-2011, 12:05 AM   #5
blackmopar
Re: Starter Grinds
when i got my truck the main prob the girlie had before sellin it was chewin thru starters - i concluded her boyfriend was getting parts store starters specd for a 64 instead of the 68 tooth flywheel on the motor swap that they needed - i went to a mini universal and shimmed properly using above paperclip guage and alls been unicorns and rainbows ever since - if your having random problemnow, check flywheel all 360, you might have a flat spot somewhere
blackmopar is offline   Reply With Quote
