Old 06-01-2007, 06:31 PM   #1
retselgerg
retselgerg's Avatar
will a high hump affect the linkage on a saginaw 4 speed
my truck was a factory big block truck and it has a high hump. will i have to remove the hump to make the saginaw work???? thanks
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB,
"some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno
retselgerg is offline   Reply With Quote
Old 06-01-2007, 07:36 PM   #2
bowtieride
Re: will a high hump affect the linkage on a saginaw 4 speed
I was wondering about this also. I have the granny gear 4 speed, and just seen a saginaw in my area for 150 bucks.
1970 LWB 250ci 4 Speed
bowtieride is offline   Reply With Quote
Old 06-01-2007, 08:25 PM   #3
dubs68SWB
dubs68SWB's Avatar
it all depends.....You will have to run a really long shifter arm if you have a bench seat, and you will also have to do a little fab work because I don't believe they are going to make anything long enough. I just did this and it was no big geal but really cool when I was done. The only thing to know is that the shifter "throw" will be a little long from 1st to 2nd and 3rd to 4th.
'68 Chevy SWB with 460 BBC
Muncie M-22 and Eaton posi rear w/ 3.73's
Corvette rallys with mini derby
caps
Sick horsepower and torque
dubs68SWB is offline   Reply With Quote
Old 06-01-2007, 10:34 PM   #4
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
which sag?
465/420 are made by sag and munc you have to be more specific
trkklr77 is offline   Reply With Quote
Old 06-02-2007, 12:34 AM   #5
retselgerg
retselgerg's Avatar
not sure i know its the one with 3 rings on the shaft, hmm i wonder if i can cut my new shifter and and add piece under the boot so it doesnt look so "home-made"??
