11-06-2013, 03:27 PM | #1 |
Fleetbed paint -two tone
This past Sunday we brough the last part to the painter to get done. I need a bit of information as to where the paint break stopps.
I have the lower body color canyon blue and the upper olympic white. I 'm not sure IF the white wraps all the way around the rear of the Tail light pillar or stops at the panel break/ I suspect it wraps around but need to make sure for the painte. Also I need to be reminded as to to paint the inside of the bed, the lowere body color? if two-tone. Thanks jake
http://s1299.photobucket.com/user/jb...23904108567829 |
11-06-2013, 03:59 PM | #2 |
Re: Fleetbed paint -two tone
This is a GM archive pic
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-06-2013, 04:01 PM | #3 |
And a picture posted by factorystock
11-06-2013, 04:01 PM | #4 |
Hope these help some
11-06-2013, 04:29 PM | #5 |
Heres my 64 GMC.
Its of course been repainted but as far as I can tell it is what came from the factory. I have also included a copy of an add that shows the 2 tone. |
11-06-2013, 04:31 PM | #6 |
great looking truck rob fisher, coming out real nice
11-06-2013, 07:06 PM | #7 |
Rob,
I have to ask, what are the wheels you have on the truck? |
11-06-2013, 08:29 PM | #8 |
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
11-06-2013, 08:43 PM | #9 |
I plan on doing mine chrome yellow on the bottom , with olympic white on top , everything from the bottom of the door windows up will be white or at least where the closest body line is ....
11-06-2013, 09:59 PM | #10 |
The fifth picture is what I was looking for, got it thanks
11-07-2013, 04:47 PM | #11 |
11-07-2013, 05:15 PM | #12 |
Another GM archive pic from 1960 shows the inside panels in black
11-07-2013, 05:55 PM | #13 |
Hmm... found these pictures of my 61 3/4 ton Custom cab OG paint and its all white inside the bed from the factory, also have a twin 61 1/2 ton and its all white in the bed. Both have white across the top of the gate also.
11-07-2013, 10:12 PM | #14 |
They are Centerline California smoothies 18 x 8-1/2
I had a sign maker friend make me the center sections out of self adhesive vehicle graphic material and i stuck them onto the rims. worked out very well, if they get damaged a little hot air and they will peel right off, and new ones can be applied. |
11-07-2013, 10:36 PM | #15 | |
11-07-2013, 10:47 PM | #16 |
i dont know personally...im a stepside guy....could it have been a plant by plant decision? just saw some bed detail in the pic and saw it was black. may also be for ad purpose to show more deminsion for the pics? the top of the bed panel is red.
11-08-2013, 03:36 AM | #17 |
Rollin' Old Skool
definitely some variations there it looks like....always interesting to see these kinda pics...just when you think you've got it figured out, another pic pops up to make you think otherwise ....I'm thinking maybe plant by plant decision as well.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
11-08-2013, 05:12 AM | #18 |
When you think it's carved in stone it changes on someone else's truck, I think there is some differences with Canadian and US GMC's pics of mine for contrast it's a US 65..Vernski
11-08-2013, 07:50 AM | #19 |
on my truck we did not follow the "exact" factory scheme. We did not wrap around the upper cab, we carried the white completely around the cab.
I like the way GMC did the white on top of the bed and stopped it at the pillars, I'll do that, But putting the white in the bed against the black wheel tubs and bed boards imho is going to clash?
11-08-2013, 11:51 AM | #20 | |
11-08-2013, 12:21 PM | #21 |
Could be....I don't know personally. The only fleetside I've ever owned was a 61 c-10 short bed from the St. Louis plant. I wasn't two toned though and was painted the body color inside the bed.
11-08-2013, 06:33 PM | #22 |
1961 crewcab
I have looked through all the pics in my 60-63 file, many are of original paint trucks, and what I have noticed is the difference between the chevy and gmc 60-61 two tone.
chevys have the 2nd color(white) along the bottom, so what I see is all the chevys started out as colored trucks, and the white was added second. The inside of the box on a 60-61 chevy is body color , not white. the 60-61 gmc 2 tone trucks have the 2nd color, (colors) along the bottom. So what it looks like is that all 2 tone gmc's started out as white trucks, and the color was sprayed along the bottom, therefore they will all probably have a white inner bed, as 60-66's photos show... ...also remember that the factory 60gmc photo is this thread, (r/w gm photostore) was a preproduction truck that was pulled for ad photos and such, that might explain the black,or red inner bed, and the upper tailgate not painted, as they probably didn't have everything sorted out for production at that time. ...as I was posting photos, I noticed something else, it looks like chevy quit painting the tailgate 2 colors in 61, so the two tone tailgate was 60 only (maybe?) .....and I have the last 2 pics of what was a 60-61 gmc off craigslist in Utah/Idaho that looks to have a body color-not white- inner bed...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 11-08-2013 at 06:50 PM. |
11-08-2013, 07:00 PM | #23 |
i agree on the preproduction pics...i have seen alot of ad items that never made production. the 60 pic i posted could be painted or could be shadowed. there are enough original painted trucks here that id be more inclined to agree with what we can see now. who knew trying to be period correct could be so hard. ill look through some more vintage archived pics i have and see if i can find any more old dealer pics that might show any detail. has any difference been found in the canadian built trucks?
11-08-2013, 07:06 PM | #24 |
and some great looking trucks jon
11-08-2013, 07:29 PM | #25 |
1961 crewcab
I wish they were mine!
a couple more factory paint pics... turquoise is a chev, green -gmc
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
