02-21-2018, 01:48 PM | #1 |
Help with vacuum lines
Ok so I need help to figure out exactly which lines I need where I live we have absolutely no emission testing so I only need the bare minimum my motor is a 454 casting number shows it to be 1975-1987. I do not have any egr stuff, efe stuff or a diverter valve. Which leads to my question do I need the efe or diverter valve do I need a vacuum canister or can I just run the Pcv,the line coming from the distributor to the carb, the line coming from the booster to the intake, and the vacuum line coming off my th400
02-21-2018, 03:29 PM | #2 |
Moderator
Re: Help with vacuum lines
Yes.
02-21-2018, 07:43 PM | #3 |
02-26-2018, 07:52 PM | #4 | |
02-26-2018, 08:14 PM | #5 |
OP is smog exempt at his location in TX per his op..
CA exemption is 75 and older.. CA SB 1239 for 35yo rolling exemption did not pass in 2016
I started out with nothing - and I still have most of it |
