02-25-2018, 05:38 PM | #1 |
power steering conversion problem
Hey all, I did a power steering conversion on my '66 using a 1970 power steering gearbox (Cardone 27-7501) and captainfab's adapter bracket.
I installed the new pitman arm (Moog K6143) however now the linkage hits the crossmember, see attached image. It did not touch with the old pitman arm and manual steering box. Did I do something wrong, or is there a way to fix this? Thanks |
02-25-2018, 08:24 PM | #2 |
Re: power steering conversion problem
idler mounted
02-25-2018, 10:24 PM | #3 |
yes my stock idler is mounted, I didn't touch it during this conversion
02-26-2018, 12:27 AM | #4 |
60-66 Nut
Try tightening up the pitman arm onto the steering box output shaft. Did you use the supplied template to locate the adapter plate on the frame?
02-26-2018, 12:47 AM | #5 |
02-26-2018, 11:59 PM | #6 |
If the nut dont do it. Maybe you got the box too far forward.
02-27-2018, 12:23 AM | #7 |
