08-02-2007, 07:28 PM | #1 |
advance curve
I have been tuning my msd pro billit HEI I have my intial timing at 16 and the 21 degree bushing for a total of 37. I have a mild 355 roller rockers mild cam and quick fuel carb desk top dyno 330hp. I have been fooling with the springs and am running the light blue and light silver and it runs like a bat out of hell.
It says when you hear detonation you have it coming in to fast or to much. I don't think I hear anything my exhaust is quite loud. my question is at 4000 rpm pulling hard will I be able to hear it ping? And will I hear it better with window up or down? With them up I don't think I hear anything with them down the exhaust makes alot of noise and think that is what I am hearing. Thanks just don't want to ruin my motor but she is running real nice.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
08-02-2007, 07:53 PM | #2 |
Re: advance curve
If your timing is too advanced, power will be lower. Seat of the pants evaluations can lead to misleading conclusions, but try to retard the distributor a couple degrees and see if it goes any better. If not, go back to starting point, if so, adjust your curve slower with more spring or tension,or run a little less total. It's pretty much trial and error, and I would rather be a little slow than broken. Another strike against too loud exhaust.
08-02-2007, 08:37 PM | #3 | |
Re: advance curve
08-02-2007, 09:57 PM | #4 |
Re: advance curve
36 degrees max.......
I BELIEVE IN JOHN 3:16 |
08-03-2007, 07:18 AM | #5 |
67-72 Addict!
Re: advance curve
My truck is 42 degrees total and likes it
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
08-03-2007, 07:30 AM | #6 |
Re: advance curve
yes i agree with 70c10 there is never a set in stone number. from what I have read 36-38 is the sweet spot.(but every engine is diferent) And I am happy with 37. I dont hear anything wierd but you know how your mind plays tricks on you.
