01-18-2010, 10:53 PM | #1 |
Need some advice installing trim
I need to drill the holes in my new bedsides for the upper and lower trim. My question is what is the best way to line up the trim. Also what is the best method for drilling the holes. Since all the rest of the trim is on the truck, can I just snap a chalk line off of it and use that as a center line for the bed? Im just afraid of denting these thinner than stock repro besides when drilling the holes. Any advice would be great. Thanks
1970 SWB Build |
01-18-2010, 11:13 PM | #2 |
The Older Generation
Re: Need some advice installing trim
I used a chalk line on mine and just drilled one hole on each end and used the adhesive clips in between. Seemed to work OK for me. Just use a new drill bit and take it slow. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-18-2010 at 11:14 PM. |
01-19-2010, 03:04 AM | #3 |
A stepped unibit is helpful when drilling the holes.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily |
01-19-2010, 01:14 PM | #4 |
Member
I never used chalk line, sounds like it would work. I have used low tack masking tape or vinyl tape to get the line right and to make my drilling marks. You didn't say in the origional question weather the bed was painted yet. If it is maybe trying running some masking tape on the bed side prior to chalking, marking and drilling to protect the paint.
I also use a tool called Center Rite to punch a mark to prevent the bit from walking. http://www.ucc-udb.com/C41-C44udb.PDF
69 C10 SWB 406 SBC 08 Silverado HD 2500 LWB Crew Cab Diesel. 06 Trail Blazer SS (Wife's Daily Driver) 67 RS/SS G-Machine http://www.hubgarage.com/mygarage/RBC67 |
01-19-2010, 03:01 PM | #5 |
I would put some masking tape down prior to running the chalk line, especially if the truck is already painted.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-19-2010, 05:02 PM | #6 |
Also, remember that the upper bed trim doesn't run straight with the rest of the upper trim. It angles down at the rear just enough to line up with the upper tailgate trim, and follows the body line just above it. Some people raise the rear, but I prefer the factory look.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com Last edited by HuggerCST; 01-19-2010 at 05:04 PM. |
