Old 10-12-2012, 06:05 PM   #1
DoubleL
DoubleL's Avatar
"De-wiring" my '66 cluster lights issue
I am finally tackling my wiring on the inside. I have all cheap aftermarket gauges (half of which weren't hooked up or wired improperly) a crappy AM/FM cassette (which they cut into the dash to install) and a top of the line (insert sarcasm) Realistic 40 watt booster and equalizer. I've removed everything and the associated rats nest of wires.
I am eventually going with a full gauge cluster that I will be custom building with air pressure and a clock but for now have restored a "lights" cluster to install until my new full gauge cluster is done.
I installed the new cluster and everything worked great except the dash lights that illuminate the cluster. I even plugged in my old cluster and can't get them to work either. They worked fine before. Since everything else (warning lights, fuel gauge,turn signals) work is this a headlight switch issue? My headlights work fine.
If anyone is interested I can post pics tonight of all the cool stuff I removed and my new cleaner interior. Right now I am headed back out to start putting things back together.
DoubleL is offline   Reply With Quote
Old 10-12-2012, 09:41 PM   #2
DoubleL
DoubleL's Avatar
Re: "De-wiring" my '66 cluster lights issue
Fixed it! It was just a gremlin
Here are some pics of what I pulled out and some "after" interior pics but couldn't find any good "before" ones.
