01-07-2011, 04:18 PM | #1 |
Axel swap 6 to 5 bolt ?
I read somewhere that moser makes axels. I want to switch my 68 burb to5 bolt rear. What is the best way ? I dont want to switch the whole diff just the shafts.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-07-2011, 04:49 PM | #2 |
67-72 parts collector,…
Re: Axel swap 6 to 5 bolt ?
Moser axles and 71-72 brake drums.
01-07-2011, 05:17 PM | #3 |
how do i get a part number ?
01-07-2011, 05:24 PM | #4 |
idk alot about it but somehow by either calling them or maybe printing it up off of their website u get a form that u write measurments down on like from end to end of the axel and from end to end of the rearend and they will make you a set to fit ur truck
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet 1994 Buick Roadmaster 1994 GMC Sonoma |
01-07-2011, 06:39 PM | #5 |
These are the 5-lug axles.
http://www.moserengineering.com/axle...spline-31.html You can also buy them from ECE. (you will have to click the drop down tab, under "axles") http://www.earlyclassic.com/catalog.aspx
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-07-2011 at 06:40 PM. |
01-07-2011, 07:11 PM | #6 |
Or if you have a, or acess to a good drill press a little common sense and a bit of patience you can knock out your six old lugs and redrill them (hubs) to 5 lug.
01-07-2011, 08:14 PM | #7 | |
I'm not sure a drill press would be accurate enough. Maybe on a mill. But at least 1 lug hole would have to be welded shut.
01-07-2011, 08:20 PM | #8 |
I was wondering the same thing about just swapping axels. The new LMC book shows axels for 70 and 71-72 for 149 a piece. The difference is the length. I will call and find out if these will work.
01-07-2011, 08:21 PM | #9 |
Thanks I will order them this week. Anyone know why do they not list 70 ?
01-07-2011, 08:52 PM | #10 | |
You could get the narrower 67-69 width rearend or the wider 71-72 width rearend in 6-lug. My '70 has the wider rearend. My '69 has the narrow rearend. If you need axles for a '70 model truck,... you will need to measure the length of them before you order their 5-lug replacements.
01-08-2011, 12:27 AM | #11 |
Restoration Virgin!
lolife...Keith,
do know if you hear this from anyone else, but you are AWESOME my friend....you always chime in on any suspension questions with clear concise answers....Thanks for your input Always!!!...you ROCK!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
01-08-2011, 01:52 AM | #12 | |
But I've just made alot of mistakes. Ha. Some more costly than others. I believe that you can learn something new here,... every day. I know I do.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-08-2011 at 01:53 AM. |
01-08-2011, 01:12 AM | #13 |
Grandpa in the rustmobile...
+1 for lowlife
He is top dog for suspension/brakes guru lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
