05-10-2012, 02:10 AM | #1 |
67 TH350 transmission pan suggestions?
I'm looking for a durable aftermarket transmission pan with drain plug, any suggestions base on experience or hear-say? Also, any experience with Moroso trans. 'blue' gasket? Looking for deals or promo codes as well. Thanks!!
- 1967 Chevrolet C/10 SWB fleetside (New Project). - 1969 Chevrolet C/10 SWB fleetside (SOLD) - 2000 Ford Mustang 232 (DD) - 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver) |
05-10-2012, 06:54 AM | #2 | |
Re: 67 TH350 transmission pan suggestions?
Part Number: MRG-9791G More Detail … Transmission Oil Pans |
05-10-2012, 11:14 AM | #3 |
I have a B&M deep aluminum pan on my TH350 and am using the Moroso blue gasket. No leaks and I like both items. Tried other pans and gaskets but these are the best so far.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
05-10-2012, 12:58 PM | #4 |
I've used TCI and Hughes cast aluminum pans. Both nice products.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
05-10-2012, 04:31 PM | #5 |
Where did you get it from? Does it come with a drain plug and cooling fins?
05-10-2012, 04:43 PM | #6 |
I'm 99% sure I got it from Jegs. It had a built in drain plug. The gasket was also from JEGS but the gasket that is included with the pan is a thick cork that seems to work well too.
It is a deeper pan than stock and hold like 3 quarts more. Cooling fins on the bottom too.
