Is my 1/2 ton a 1 ton? VIN # decoding
Im trying to decode the VIN number (PE320J160589) on my 1970 C10. Does anyone know what the first letter P? Ive found it designates "forward control" but i don't know what that is. Also, the 3rd number is a 3 which designates a 1 ton?? Is it because of the mobile home chassis option i wonder?
#2 | |
Re: Is my 1/2 ton a 1 ton? VIN # decoding
That looks like the SPID for a totally different truck. In addition to the model number R05 is dual rear wheels, for example. Are you saying the VIN on that SPID matches the VIN on your truck? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I'm guessing your glove box door has been replaced. Have you check your spid vin to your actual vin?
1972 C10 - It might be old, but it's not slow |
Holy Frankenstein batman. I dont know why i didnt think to check the actual VIN but you are right, the door must have been replaced. The VIN is CE140J
Whew! That was close....not to be a wet rag but if you had that P truck VIN on your truck....that would be bad.
K
![]() Join Date: Jun 2005
CE140J designates a 1970 Chevy 1/2 ton 2WD with a V8 built at the Janesville, WI plant.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Yep, and with a wheelbase of 157" that would be a LOOOOOOONNNNNGGG bed!
POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
Trust me, the SPID is the last thing I look at when I am buying a C10, there are so many reproduction SPID's and glove box swaps, now that's usually done on Super's and desirable trucks, not so much a bread truck hahaha, I'm sure it was just a junk yard replacement. Glad we got that issue solved.
What? No 13 foot bed option in 1970!?!😂. I just wanted to replace or rebuild the carb and find out the truck has all kinds of donated parts, 350 block, 327 intake manifold and a two barrel carb off a 1969 Bel Air. Simple right?
Just buy my ZZ4 Crate 350 and TH400, and I'll build that boosted storker 400 I've always wanted
#11 | |
I didn't realize StepVan dashes used the same dash panels. I thought they used a different instrument cluster
#12 | |
K
