03-25-2015, 05:19 PM | #1 |
2.5" ram's horns in 82 2WD truck
Will std or aftermarket 2.5" ram's horns manifolds work in an 82 C10 2WD? My concern is the outlets will be too close to the cross member to install head pipes.
I really like these from Speedway. http://www.speedwaymotors.com/Smooth...Raw,94194.html
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
03-25-2015, 06:10 PM | #2 | |
Re: 2.5" ram's horns in 82 2WD truck
I have heard that the motor mounts are pretty close for these rams horns, but don't have any experience myself. Good luck |
03-26-2015, 08:13 AM | #3 | |
*** Never mind. I found what I needed. I've been looking at 97 manifolds, which are similar, but should fit the raised ports on my Vortec heads a little better, Thanks.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 03-26-2015 at 08:46 AM. |
03-31-2015, 08:05 PM | #4 |
driving is in my blood
I had 2" ramhorns in my 79 with a vortec 350 motor in it. Just barely worked, I doubt 2.5" will work at all.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
06-09-2015, 06:52 PM | #5 |
Well, I just ordered a pair of Dorman stock replacement cast iron manifolds for 1996-2000 pickups with Vortec heads. I feel sure they will fit and clear everything, but I'll have to fabricate some head pipes, since they drop down in different places and angles than 81-87 trucks.
09-20-2015, 10:52 PM | #6 |
Collector of Projects
Bringing this back up... Looking at a 2wd 78 Blazer with a 1991 SBC 350. Has anyone run these aftermarket Rams horn manifolds with 2.5" secondaries?
Are there any clearance issued to the engine mounts, cross member or stater? |
11-29-2016, 07:11 PM | #7 |
i just ordered the 2.5 hoping they fit
11-30-2016, 09:50 AM | #8 |
I ran some stock rams horn and was really tight around the starter [heat soak]
11-30-2016, 10:27 AM | #9 |
Stock ram horns are really tight. The Speedway aftermarket units are angled closer to the block which will prob only make things worse.
11-30-2016, 12:42 PM | #10 |
I ordered the corvette 2.5 from ecklers truck will receive them Thursday or Friday. did order a heat blanket for the starter and some header wrap for the exhaust.
12-01-2016, 10:23 AM | #11 |
a mini starter would help too
12-09-2016, 05:58 PM | #12 |
Funny this thread I started came back alive.
After all my work fabricating head pipes for the 96-02 exhaust manifolds I mentioned above, I ended up installing full-length headers a year later! The manifolds had 2-1/4" openings, but necked down to less than 2" inside. Same with the cheap mufflers I had, only they actually necked down to 1.5" inside. So I replaced them with Walker Dynomax Super Turbos with 20-inch case. Anyway, the headers were a hassle to install, and I had to fabricate pipes to run over and under the crossmember (different on each side). However, leaks are an old wives tale, IMO, if you use good gaskets and hardware. Gotta say acceleration and throttle response are noticeably improved. Also, a business manager friend tells me I can't worry about "sunk costs".
12-09-2016, 06:03 PM | #13 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-09-2016 at 06:12 PM. |
12-09-2016, 11:43 PM | #14 |
Hi There, might be a goofy question, but why do you want to use Rams Horns? I imagine you might get a little better flow with 2.5", but you also have to re route your spark plug wires (and use ridiculously long ones). I had a couple vehicles with Rams horns, and it seemed they "baked" the lower part of the valve cover gaskets because they came up high right beside them.
12-10-2016, 02:36 PM | #15 | |
