12-12-2016, 12:49 PM | #1 |
700r4 question
Anyone know if a 700r4 from a 89 suburban would be a direct swap into a 85 k10?
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
12-12-2016, 02:11 PM | #2 |
Re: 700r4 question
Only if the Burb was 4wd.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
12-12-2016, 02:33 PM | #3 |
Re: 700r4 question
Just did the same swap, transfer case and all, no problems.
12-12-2016, 04:42 PM | #4 |
Re: 700r4 question
I thought that the torque converter lock up might be different from 85 to 89.
12-13-2016, 09:12 AM | #5 |
Re: 700r4 question
12-13-2016, 12:34 PM | #6 |
Re: 700r4 question
I prefer to use the lockup torque converter on a toggle switch anyways otherwise they lock up at the wrong time in my experience. I use a brake switch though so that it will un-lock when you hit the brakes.... Had a bad situation during a panic stock where the converter was manually locked and the engine stalled causing me to loose the power brakes and steering.... Almost caused an accident.
12-13-2016, 06:14 PM | #7 |
Re: 700r4 question
That combination is highly sought.
Early on, the 700R4 was most often combined with the NP208. However, the NP241 is an updated version of the NP208, and it only came with a mechanical speedometer for one year. 1989, in the suburbans and blazers. Every year after, the 700R4 and NP241 combo had an electronic speedo. The NP241 is generally considered to be a better option than the NP208 because you can eliminate the slip-yoke. But if you have an early vehicle and need a mechanical speedo, you have to search the junkyards for a 1989 suburban or blazer, because that was the only year. Ask me how I know...
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
