04-22-2016, 08:04 PM | #1 |
Need carburetor suggestions for 283ci
I have been fighting issues with a 1977 qjet for months now. every mechanic I take it to adjusts it or rebuilds it and tells me its as good as it can get. I'm finally to the point I believe them. What would be the definitive answer be when it comes to this problem? I am in the market for a new carb but am having trouble figuring out what to get. Id hate to order one only to find its the wrong one for this engine. I would like to keep it original with a Rochester product. Any experts on carb setups for this engine? Its a stock 1967 283ci with headers, turbo350. Help!
http://67-72chevytrucks.com/vboard/s...25#post7532025 71 Cheyenne K10. 283/Th350/NP205. 3.07s non posi. 31x10.5 Bighorns.L31 350 Vortec swap in progress. 79 Suburban K20. 350/350. 6" lift. 35x12.5 Toyos. 93 Burb K1500. 350/4l60e Parting out. 2001 Tahoe LT, 5.3, autoride, 265/75s, leather, loaded, family hauler, 243k miles! |
04-22-2016, 08:19 PM | #2 |
Re: Need carburetor suggestions for 283ci
It may not be the most refined piece, but I've had very consistent, reliable service from the 4G on my Suburban. Just a plain old square bore, 486 CFM, jet carburetor with manual choke. 486 CFM should be plenty for a stock 283. There are several options for aftermarket spread-bore carbs. that are probably less finicky than the Q-jet, but I can't speak to the traits of any. A good Q-jet really is a good piece, but they're so hard to get there sometimes...
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
04-22-2016, 08:22 PM | #3 |
Thanks Alex. That may be an option worth looking into. Where might one pick up a 4G? I was trying to stay away from a new intake but ill do whatever it takes to get it going.
04-23-2016, 01:32 AM | #4 | |
04-23-2016, 07:06 AM | #5 |
I know this isn't the way you want to go but an after market intake and then something like either a 390 Holley or a 500 Edelbrock might be the ticket. Now if you wanting to stay with what you have [intake wise] talk to Ruggles [cliff] he IS the Quadrajet man from all I've heard and read. He literally wrote the book[several of them] on how to make them run right.
04-23-2016, 07:53 AM | #6 |
I have Ruggles' book - haven't read it yet but I intend it to be my study aid when I go through my '85's carb.
If it was me I'd probably buy a good core (Ebay, etc.) and rebuild it myself. They aren't nearly as complex as a Q-jet. IIRC they came in 3 CFMs, dictated by the size of the primary and secondary bores. I'd hate to have to swap intakes, too, but my humble opinion is the squarebore Rochester is very well suited to these small, tame truck engines. Then again, I don't know of any inherent reason your 283 shouldn't breathe fine through a Quadrajet, and before you swap intake and carb. you might be much better off just to buy a quality reman Q-jet. I'd read up before taking that leap - googling "Quadrajet substitute" should yield ample reading material on carbs that will fit your intake but aren't as touchy.
04-23-2016, 09:14 AM | #7 |
I have a 1962 283 and I am running the qjet from the 1972 350 that was in my C30. I had to rebuild it but it seems to be working fine.... was my first carb rebuild. My first engine swap too...
72 C30 283 flatbed 66 silver eagle bus |
04-23-2016, 11:14 AM | #8 |
Good ideal all around. 4gc may be the answer but at the same time these 283 did come with an option for a qjet, dual jet, dual qjets, and an early fuel injection system. The intake is original to the truck. Dual plane spread bore pattern. I let another mechanic work on it yesterday and it is really running bad now. Backfiring through the carb and wanting to die when gassed from a stop. He tuned it by ear. I'm on my way to pick up a vacuum guage right now. Going to try another go at it myself. Has anyone sent there carb off to be refurbished? Also what is the correct rod and jet size for these engines. I've done some research but can't nail it down. Thanks for all your help guys. Good job on your first carb rebuild and engine swap!
04-23-2016, 02:13 PM | #9 |
Since the vast majority of Q-jets were installed once there was some concern for emissions, I'd try to find rod/jet specs for '66, '67, and '68 models - even if they aren't truck applications, a low-horse passenger car variant of a 283/327 should be close enough to start. I'm in the (slow) process of dialing in the jets on my 4G, on a smog-era 350 w/624 heads - I can only guess how the mixture needs will differ from the '67 327 the carb. came on, so initially I'm honestly guessing within about a .010" jet size range. Started with 61/68, then the plugs were pretty black so I moved back to 54/61 and it still runs alright but may have lost a smidgen of power and smoothness so I think my next adjustment needs to be back up. Carb. and ignition tuning on modified or hybrid-factory combos is tedious but I'm enjoying the learning curve.
04-25-2016, 11:14 AM | #10 |
A few years ago I had Cliff rebuild and tune a Q-jet for my 1967 Malibu 283 engine. It has worked nearly flawlessly for over 40,000 miles now. The downside is at that time he had a 1 year waiting list. I think I may still have the records for the rod and jet size he used. May take me a while to find them tho...
04-25-2016, 11:38 AM | #11 |
Rod and jet size would be a good start. I'd love to have a cliff built carb but I'm too impatient thanks
04-25-2016, 01:03 PM | #12 |
I have had great luck with the Summit line of carbs. they blend what is great about holley ( power valves, accelerator pumps, dual line feed and Edlebrock, simple choke, top loaded design no leaky bowls. Mine ran out of the box and only needed idle speed and idle jet tune. get the smallest size for you engine. But dont worry, even a 600 isnt too large. carbs mix the air by the used volume. they never made a Q-jet smaller than 750 cfm, so I think you'll find any smaller holley, summit or edelbrock will work.
Now to the sticky part...nothing wrong with a properly set Q-jet. They worked for 40 years on every SBC ever made till fuel injection. You might have a bad one, but its not the Qjet designs fault. I'm going back to a Q-jet myself.
1970 GMC Stepside Short Gone...Factory 350 V8 Now...4.8L LS |
04-25-2016, 02:38 PM | #13 |
You may want to stay original, but I will say that I just ordered an Edelbrock for my truck. It will be the third one I have installed - I bought it because of how great they ran on two other vehicles. Getting rid of a double pumper for it.
1968 C-10 Suburban - Original 396/TH400 2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen 2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck 2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have. |
04-25-2016, 03:29 PM | #14 | |
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
04-27-2016, 07:42 AM | #15 |
Well, I've searched everywhere for those rod and jet sizes and have not been able to find them. If I do i will post them. Thats gonna bug me now...
04-27-2016, 09:56 AM | #16 |
Well thanks for looking. I think ive decided to try and get this thing driveable again and just start building the 350 I have sitting around. It was always the plan anyways. However, not having this thing tuned properly will certainly bug me. I have searched far and wide for 283 original rod/jet sizes and for some reason its difficult to find info on these particular engines.
04-27-2016, 10:00 AM | #17 |
350 is a better motor for making power, but lacks the "cool factor" that a 283 or 327 has.
04-27-2016, 10:39 AM | #18 | |
There's more than just the proper rods and jets to make a Q-jet work properly on a 283. Cliff doesn't have time to answer the phone all day. Best to email him www.cliffshighperformance.com A Q-jet would be the best carb as far as tune-ability and parts availability. Send Cliff your carb number and tell him details of your engine/car build, He can send you the exact parts you will need, and get a copy of his book. I'd get a stock cast iron non EGR intake, it will work great on your 283. |
04-27-2016, 04:03 PM | #19 |
Good idea talking to Cliff. ill send him an email. I do have the original intake on the engine. Dual plane cast iron non egr. I would be more inclined to keep the 283 if I could make it run right It only has 50,000 miles on the rebuild. GM HEI and long tubes are the only mods I know of. PO didn't say if they cammed it. Sounds good through dual flowmaster 40s but not a lot of lope so I'm thinking not.
04-27-2016, 04:11 PM | #20 |
DOn't know why you're so stuck on an original Rochester. I promise you that you would be 100% happy if you bolted this thing on. It's cheaper if you don't get the silver version BTW. I have a 650 arriving today! Third one I've used, they are the best. I've had my truck a short time now and it runs poorly. Stick it on and it will work. I'm not even going to waste time messing with the one that is on there. You already have headers and HEI, so staying 100% original looking is already out of the door.
http://www.summitracing.com/parts/edl-1404/overview/
1968 C-10 Suburban - Original 396/TH400 2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen 2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck 2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have. Last edited by AnotherWs6; 04-27-2016 at 04:17 PM. |
04-27-2016, 06:14 PM | #21 | |
04-27-2016, 08:11 PM | #22 |
The 283 is not going to be over-carbureted with a Quadrajet. Pontiac used one on a 230 cu in six.
Qjet secondary throttle valves are mechanical, but above them is the air valves that opened by air flow. The air valves only open as much as the engine can use so that you don't get a secondary bog. The air valves are spring loaded and the spring tension is adjustable. If the 283 doesn't flow enough air, the air valves simply don't open more than needed. A 1977 Qjet might be a piece of SMOG crap. Some later SMOG Qjets even had plugs over the mixture adjust screws so you couldn't adjust them. I agree with your reasons for keeping a Qjet. It might be that you need to find a different one to rebuild. I found this on Wikipedia and they go over some of the problems that can prevent a successful rebuild. https://en.wikipedia.org/wiki/Quadrajet Read where it says Drawbacks.
'67 GMC 2500, 292, 4spd, AC |
04-27-2016, 08:29 PM | #23 |
I have looked into an edlebrock and that may be in the cards. However I will need an intake too as I have an original 1967 spread bore manifold. This bumps the price if you get the package deal to somewhere in the neighborhood of 500 bucks. Then theres linkage choke and vacuum lines etc...This has been rolling around in my brain, but if I can spend a few dollars and change out rods and jets it just seems like the better way to go ATM. I do have a 350ci I am building this summer and I will probably go with the edelbrock intake and carb package. You have to be careful going with bolt on performance if you don't know what your doing though. Change cam, intake and fuel delivery and you could be spending quite a bit of time tuning to get it just right.
This is where id insert a previous message to replay too but I don't know how I have adjusted the secondaries but haven't had a lot of time to mess around with the old truck the past few days as work is getting hectic on the farm. Before I took it to the last "mechanic" I had the secondaries pretty close to dialed in. The problem I was having at that point was a surging? hesitation? with my foot to the floor and no increase in speed. No bog though. I travel over a pretty steep grade once a week or so and I usually have to have my foot firmly planted in the throttle to get over the hill. At 65-70 if I pinned it when it was running good I never got a kickdown. Is this normal? If I slowed to 45 and pinned it it would kick down and open right up. There is a steep learning curve and I have yet to figure it all out when it comes to a q-jet(this is after a couple of years fooling around with them on different applications. I want that EFI like throttle response people talk about.
04-27-2016, 09:11 PM | #24 |
Your surging and lack of power could just be a lack of a good timing curve.
What's your initial timing? |
04-27-2016, 09:17 PM | #25 |
Well I had it worked on months ago and the guy had it tuned to the condition of the carb at the time. Not sure where he had it but ran ok. Right now it's at 12 btdc. I have a timing tape coming in a day or two along with a piston stop and new innova light with tach reading. I will find true tdc and put the new tape on and have a better answer for you initial/total.
By the book it's supposed to be at 4btdc but I am at 5000ft here.
