Old 06-28-2016, 07:10 PM   #1
50dude
50 gmc gauges
hello couple gauge questions 1) stock temp gauge on 350 what are you guys doing sensor is to short 2) there was some 12v conversion done on truck is there a way to tell if the gauges were done thanks
50dude is offline   Reply With Quote
Old 06-28-2016, 11:02 PM   #2
mr48chev
mr48chev's Avatar
Re: 50 gmc gauges
Classic parts sells this gauge for Chevys with V8 engines that has a longer capillary tube on the gauge http://www.classicparts.com/1949-53-.../#.V3M58jXSuX4
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 06-29-2016, 02:34 AM   #3
joedoh
joedoh's Avatar
Re: 50 gmc gauges
here is the GMC version of mr48s link
http://www.classicparts.com/1947-51-.../#.V3Nrno7F7dQ
if you want to know if the gauges have been converted to 12v, check the bulbs, they will be marked 6v if unconverted. most of the gauges are mechanical and 12/6v will not matter (the GMC also uses an ammeter which doesnt matter what voltage), but the gas gauge will have either a converter on it or will have been replaced with a 12v version, which is why I say to check the bulbs.
although I did a couple 6v/12v switchovers on VW bugs in my younger days and we just left the bulbs 6v so they would be brighter. left the starter 6v too, extra rpm!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 06-29-2016, 01:08 PM   #4
whitedog76
Re: 50 gmc gauges
I've actually been researching the same thing.
Longer oil pressure tube, longer coolant tube, runts resistor, etc... If I'm not mistaken you can buy a converted fuel guage too. VDO makes a 12 heater motor that works also.
Don't forget ALL yor light bulbs.
Here's a couple articles from Patricks.
http://www.patricksantiquecars.com/a...-12-volts.html
http://www.patricksantiquecars.com/a...lternator.html
whitedog76 is offline   Reply With Quote
Old 06-29-2016, 02:47 PM   #5
50dude
Re: 50 gmc gauges
thanks !!
Old 06-29-2016, 03:27 PM   #6
mr48chev
mr48chev's Avatar
Re: 50 gmc gauges
Looks like I didn't scroll down the page far enough. I knew there was a difference between the Chev and GMC gauges but couldn't remember what.
Old 06-29-2016, 06:22 PM   #7
50dude
Re: 50 gmc gauges
another question any ideas where i can get replacement lamp sockets for the gauges thanks
Old 06-30-2016, 10:41 AM   #8
whitedog76
Re: 50 gmc gauges
Here's just an idea that I had awhile back. I had some LED tape leftover from a job I did. (I'm an electrician)
I hooked it up to a 14v drill battery. They are bright, but dimmable, plus you can get about any collor you want.
BTW, those are cell phone pics, they look alot brighter than they actually were.
