09-23-2011, 01:06 AM | #1 |
stock 307 redline?
I have a 71 c-10 w/ 307 thats stock, 3 on the tree. Any idea on what the RPM redline would be?
71 C-10 - 307 - 3 on tree 01 Ford Explorer 5.0 v8 96 Mercury Cougar v8 79 Trans Am 403 Olds |
09-23-2011, 01:32 AM | #2 |
Re: stock 307 redline?
I'd guess 5000 RPM...although a stocker 307 would probably be out of breath by then.
'72 C10 Highlander | '69 GTO | '06 VFR800 | '96 XR250 |
09-23-2011, 09:03 AM | #3 |
the boat guy
when the valves start floatin.
03-31-2012, 04:39 PM | #4 |
I dun gradjiated collij!!!
HA HA been there done that...
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
09-23-2011, 11:02 AM | #5 |
Just remember, you have a 40 year old motor and if it has never been rebuilt, it might be getting a little tired. Although small blocks are durable they are not immortal. If you wind it out to 5000 rpms on a regular basis, you will more than likely be looking for a replacement.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
03-31-2012, 03:25 PM | #6 | |
09-23-2011, 11:22 AM | #7 |
The shorter 3.25" stroke will rev pretty good. It should be able to handle 6000 revs. However, the stock wheezy heads are limited on top end power. As mentioned above, she'll be out of breath by 5000 rpm.
09-23-2011, 12:20 PM | #8 |
I had a 67 327 that was good up to about 4500 when it would fall flat on it face after that
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
03-31-2012, 03:33 PM | #9 |
Two observations, not be taken personally.
1. I see no reason to take the old 307 past 4500 rpm, it will be all out breath by then anyways. 2. I see no reason to rebuild a 307 with so many 350 engines out there if you are concerned about performance. If you're not concerned about performance, then just shift at 3000 rpm and call it a a day. |
03-31-2012, 07:31 PM | #10 |
Keep it on the lower RPM range. Want a real boost? Put a Comp Cam 260 cam and fresh timing chain in it. You will not believe the drastic improvement it will make. The factory cams were weak in every way.
03-31-2012, 08:29 PM | #11 |
Just feel of it , you can tell when it has had enough . be gentle and it may last a long while more.
03-31-2012, 10:16 PM | #12 |
I would dare to say that it is all done making the most power and torque by 4250ish. Any more revs that that you are just reving it up for revings sake
