03-30-2012, 09:43 AM | #1 |
67cheby
Thinking about going with an aux trans cooler for my 700r4 looking for input
in the thought line of keeping my engine compartment as Smooth as possible i am thinking of getting rid of my transmission cooling lines running off of the radiator and mounting an auxillary cooler under the cab on the inside of the frame rail , I am looking for input , Is this a good idea, will it keep my 700r4 cool enough, what brand/style/length, i have never used one before so just looking for some input !
03-30-2012, 09:48 AM | #2 |
67cheby
Re: Thinking about going with an aux trans cooler for my 700r4 looking for input
also does anyone know what this is for on my radiator ?
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 03-30-2012 at 01:10 PM. |
03-30-2012, 10:50 AM | #3 |
Its a Truck Thing......
I have heard both good and bad....I would not remove the radiator cooler lines, I would add an additional cooler to the system to help with the heat transfer. Dont chance it with a 700R4.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
03-30-2012, 12:15 PM | #4 |
Village Idiot....
I used a 30' finned heat sink cooler on my truck without any problems (I've had the tranny checked twice) if I was you I would mount the cooler on the outside of the frame away from the exhaust.
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
03-30-2012, 01:06 PM | #5 |
67cheby
Thanks Keith i think this is what i am going to do !
03-30-2012, 09:09 PM | #6 |
Looks like a fitting for a heater hose with a threaded in plug. Is the plug plastic.
I would look for remote transmission cooler with an electric fan too make sure you get enough air flow. |
03-31-2012, 08:53 AM | #7 |
I am building a 36 chevy street rod and just had a good discussion about this with my local and well established transmission shop. I want to do the same thing as you and asked the owner who has been in business over 30 years and he said running just the external finned heat sink type would be fine, and not a problem UNLESS I planned to drive the car in the winter. He explained that those finned style coolers will not allow the fluid to be warmed to the minimum operating temperature when it's cold out and that is not a good thing. Just something to consider.
Jeff Posted via Mobile Device
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
03-31-2012, 09:17 AM | #8 |
We installed mine on the radiator support in front of the radiator and has been there since 08..here is a picture.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
03-31-2012, 11:17 AM | #9 |
67cheby
thanks everyone for the info i do appreciate it !
03-31-2012, 01:31 PM | #10 |
It is agood idea to have the trans fluid warm up if you are going to drive it in cold weather. TruCool coolers work good. Their LPD series allows the fluid to flow through only a small portion of the cooler untill it warms up and then will flow through the rest of it. They come in all different sizes so finding one to fit is pretty easy. I am sure there are other brands out there that work the same too.
